07-23-2009, 12:31 PM | #1 |
Quarry Creeper Join Date: Jul 2005 Location: Utah
| 4 channel mixing question?
I use a 4 channel on my clod crawler and was wondering if I could wire in some switches to mix two of the channels. I would like to be able to have both front and rear esc's "act" as though they were on the same channel if I choose to. Or just like a clod using one esc. Does anyone know how to do this, or could point me in the right direction? |
07-23-2009, 12:33 PM | #2 |
Need a more info from you. Are you using two ESC's? What radio are you using? If you aren't using a nice radio and 2 esc's than most likely your anwser is no. |
07-23-2009, 12:42 PM | #3 |
Yes running 2 ESC's Futaba skysport 4 (cheap) TX What does the quality of radio have to do with it? Last edited by jevyguy; 07-28-2009 at 10:12 AM. |
07-23-2009, 12:55 PM | #4 |
Rock Crawler Join Date: Feb 2008 Location: UK
07-23-2009, 01:48 PM | #5 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I'm pretty sure the skysport 4 doesn't have any mixing. Ya may be able to use a novak dig to get it to work.
07-23-2009, 01:54 PM | #6 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
a " y" harness would work
07-23-2009, 01:57 PM | #7 |
07-23-2009, 03:13 PM | #8 |
The Skysport TX has very little adjustments. No EPA's or mixing. All it has is servo reversing and trim adjustments. I only would want the mixing option on a rare occasion. I currently drive with my left thumb: up and back is front forward/reverse, and left to right is rear forward/reverse, and I like it this way. I was just wondering if there was a way I could mix the two (on rare occasions) by adding some sort of switch combo to the pot(s) in the radio. |
07-24-2009, 12:59 AM | #9 |
If all you want to do is have the option of running both ESCs off the same pot (left up&down), try this: Disconnect the centre wire from the left left&right pot. Connect it to the centre (common) terminal of an SPDT (on-on) switch. Connect a wire from one of the outside switch terminals to the centre terminal on the left&right pot. Connect a wire from the other outer switch terminal to the centre terminal of the left up&down pot. With the switch one way, it will work as it does at present. Flip the switch, and both channels will get the signal from the up&down pot. I've never tried this, but it's the only way I can think of to do this, short of buying a computerised Tx. I'm not sure if feeding one signal into 2 inputs will cause any problems, so play it safe and keep the wheels off the ground when you switch on for the first time. I don't think it'll cause any permanent damage, it just might react funny. |
07-24-2009, 04:59 AM | #10 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
this is the reason I went from a pretty decent jr sx600 to a dx6. Check around they can be found pretty cheap sometimes. They have all the mixxing options you'll ever need!
07-27-2009, 09:48 PM | #11 | |
10-11-2009, 01:51 PM | #12 |
Rock Crawler Join Date: Aug 2008 Location: Tucson
Awesome info clockworks.
