Thread: Series or Paralle
Old 09-24-2004, 06:15 PM   #1
Default Series or Paralle
I was wondering what people are running on the clods when they wire there motors, Series or Paralle ? This would be running a Super Rooster?
RCCasper is offline   Reply With Quote
Old 09-24-2004, 06:25 PM   #2
06 Super National Champ
JasonInAugusta's Avatar
Default Re: Series or Paralle
Parallel
JasonInAugusta is offline   Reply With Quote
Old 09-24-2004, 06:30 PM   #3
bRIBEGuy's Avatar
I run parallel on my Clod axle crawler. If you run a clod, you can use this set-up to slightly favor the rear wheels (run the power there first from the ESC, and then to the front) and help to stop the ever anoying motor stall problem.
If it's for a shafty............I dunno. I'm actually building one now, and was toying with the idea of running them in series. I figure the longet run times and higher torque would be cool............and with duel motors running to one tranny (through gear reductions in this case...), I don't know if you'd ever have to worry about stalling. Anyone tried this, or have thoughts/opinions?
bRIBEGuy is offline   Reply With Quote
Old 09-24-2004, 07:23 PM   #4
Location: In the shop terrorising the cat with the heli.
bRIBEguy is correct. Run from your speed controll to your rear motor first then long wires from your rear motor to your front motor. I run this setup on digger and have yet to have a motor stall.
aubie is offline   Reply With Quote
Old 09-24-2004, 09:15 PM   #5
Parallel.
kjr2 is offline   Reply With Quote
Old 09-25-2004, 01:55 PM   #6
I run my Clod's silver cans in parallel, but I'm not a full blown crawler yet. I wired the rear first because I heard it was "better," but never knew there was a specific reason for it.
dabid is offline   Reply With Quote
Old 09-25-2004, 02:22 PM   #7
bRIBEGuy's Avatar
So going back to the other side.....................are there any shafties running series to dual motors?
Old 09-26-2004, 03:53 AM   #8
I run p2k2 pro's in series with 9 tooth pinions and a robinson 78tooth spur on my E and i dont have any real stall issues even with kongs. I would like to be a bit lower though, that would guarantee no stalling.
WHITE-TRASH is offline   Reply With Quote
Old 09-26-2004, 09:03 AM   #9
That's odd.
Parallel is parallel. Current still takes the path of least resistance. As the load on a motor increases, the resistance increases and more current will go to the motor with the least load...usually the front.
I've heard people say that if you run a "Y" from the ESC to the motors it helps, running from ESC to rear to front helps, etc.
The bottom line is parallel is parallel. Voltage is constant, current is additive, and current still takes the path of least resistance.
Electrons don't know (or care) where they're "supposed" to go first, they just go where it is easiest.
Old 09-28-2004, 06:57 PM   #10
bRIBEGuy's Avatar
This is true. Of course, a length of wire imposes a load also. I believe the idea of wiring to the back motor first is so you have a shorter electrical path there then you do to the front motor. Shorter wires to the back equals less electrical resistance, and as such could allow the rear motor in a clod to see a slightly higher amount of power. Yes, in a "stall" situation the electricity will run to the overall path of least resistence, but running rear first then front allows for a system that inheirently biases that path (even if ever so slightly) to the rear. In theory, this could be excentuated further by running a lower gauge wire to the rear motor (i.e. 10ga), and a higher gauge to the front (14ga). Would it make a huge difference? Probably not. Would it make any difference? Likely.
I say any trick that could work, is at least worth a try. Esspecially when us clod-axle boys are up against the eternal 4 wheel churning of the shafties (this of couse is pure speculation as I'm pretty sure I'm alone in the Calgary, Alberta, Canada crawling world).
Ya.
Old 09-29-2004, 05:02 PM   #11
The difference in resistance between the length of wires is so minute it won't make a difference. It'll still show as a short, practically 0 ohms. At that low of a resistance more of the reading you see on the meter (talking about thousandths and ten-thousandths of an Ohm) will be from the connection between the leads and the cable rather than the cable itself.
The rear motor stall is just the nature of the beast with a Clod.
Old 09-29-2004, 05:08 PM   #12
bRIBEGuy's Avatar
"The rear motor stall is just the nature of the beast with a Clod."
Sadly it's true..................and while I love my clod-crawler, the possibility of never stalling has forced my twisted mind to start work on a second crawler...............a super basterdized shaftie with all kinds of savage/emaxx/revo/custom parts. It's a few months off still.........but soon I'll join the realm of shaft drive.
Soon.............
Old 03-27-2005, 07:31 PM   #13
Soon.............
well said, well said
SiameseDog is offline   Reply With Quote
Old 12-22-2005, 01:46 AM   #14
why not put a resistor at the front motor
toyota_yes_please is offline   Reply With Quote
Old 12-22-2005, 02:06 AM   #15
I dont see then need for dual motors.... granted I am only running 2.2's with my 45t lathe, but I can get them so bound up that it would break something if the tires keep spinning
camoTJ is offline   Reply With Quote
Old 12-22-2005, 02:16 AM   #16
55T lathe on a supercrawler shaftie is all i've ever seen needed.
Trike Kid is offline   Reply With Quote
Old 12-22-2005, 03:18 PM   #17
TEAM MODERATOR
EeePee's Avatar
Even though this thread is from 9/04!!!!, I can add to it with this:
Two motors in series on a TXT is pretty sweet.
Two 27 turn motors in series out-powered a single 55 turn motor, and run times were VERY similar. But, having two motors mounted as high as they are in the TXT was not so sweet.
And a resistor on the front motor in a Clod seems goofy. I used two different pinion sizes. And will be trying two different motor winds when it ain't so freaking cold!
EeePee is offline   Reply With Quote
Old 12-22-2005, 03:37 PM   #18
What about a large capacitor on the rear motor wires? Just kidding I've read some clod owners have started to use two speed controls in their clodbusters. Does that eliminate the motor stall?
Cubman is offline   Reply With Quote
Old 12-22-2005, 09:00 PM   #19
Talk about bringing back the dead!
I have been running a clod since my intro to crawling, and I have also dabbled in the shafty world a little.
Here's my take on clod stall. I think Clod stall is great. I think when used properly it's a real advantage against a shafty, mainly in climbs.
The stall during a climb allows my front wheels to dig around a little until they hook up without the rear tires hitting the obsticle and flipping the rig over backwards.
example A little pebble at Green River
Heavy
Heavy is offline   Reply With Quote
Old 12-22-2005, 11:09 PM   #20
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I think the clod stall is useful, but very infuriating at times. The best way I found to control it was simply two esc's.
I run (ran) my clod motors in parallel.
JohnRobHolmes is offline   Reply With Quote
