09-20-2009, 01:31 PM | #1 |
Rock Crawler Join Date: Feb 2008 Location: Anniston, Alabama
| Independant ESC conrtol with this radio???
Anybody know if this radio can be configured o run an ESC off of each stick like you can do on a DX6 or one of the more expensive radios? Also, can you do the throttle return spring mod on the other stick?
09-20-2009, 01:51 PM | #2 |
You would probably have to run one esc on the right stick and one on the left. I didn't see any mixing capabilities. But it would work if thats the way you want to do it. And you can always modify to make things the way you want, it may be as simple as removing the ratchet on the left stick to make it self center. |
09-20-2009, 02:14 PM | #3 |
[QUOTE=666;2004202]You would probably have to run one esc on the right stick and one on the left. I didn't see any mixing capabilities. But it would work if thats the way you want to do it. I have never driven a crawler with a stick radio, so maybe I am confused. But isnt that how you set up a stick radio anyway? One ESC on each stick? Isnt that what gives your your independent speed control of each axle for both front and rear dig? |
09-20-2009, 02:17 PM | #4 |
I set mine up so that my throttles are on the left stick-mixed, steerings on the right.
09-21-2009, 01:36 AM | #5 |
Rock Crawler Join Date: Feb 2008 Location: UK
That Tx looks the same as the Turborix/Hobbyking/Flysky. It has 3 mixes available. You can have independent stick control of the ESCs, plus you can, with the flick of a switch, control both from one stick. It actually does a couple of things that the DX6i can't! You can modify the throttle with a spring, but you'll have to make the parts. |
