10-05-2009, 01:49 PM | #1 |
Rock Stacker Join Date: May 2009 Location: Belo Horizonte -Brazil
| Turnigy Accucel-6 brokem. HELP-ME
hi folks.. I make a mistake ( shortcut in power suply) on my Accucel-6 and I toast the BAB2CH IC. But I search on google and I don't find anything about this IC, anyone knows a substitute for him? the people says that Accucel-6 is a copy of Bantam-B6, in such case is possible the B6 uses the same IC but with a "comercial" ID numbers? Thanks |
10-05-2009, 04:02 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
Looks like a voltage regulator. maybe this one? I don't know for sure, but it's worth a try? http://search.digikey.com/scripts/Dk...=497-4468-1-ND |
10-05-2009, 04:32 PM | #3 |
thanks... but I guess that is not the same IC.. but I can try... a friend open a Bantam -BC6 and the same IC on the board ( identical as Accucel) use a IRF7413PBF http://pdf1.alldatasheet.com/datashe...RF7413PBF.html so, I will search one these IC here em Belo Horizonte to buy.. thanks |
03-16-2010, 08:00 AM | #4 |
Newbie Join Date: Feb 2010 Location: Lewisport
How could you tell this part was the one that was messed up. I have one of these that i didnt have enough amperage to and it now says connection break and will not charge any idea and how I could fix it.
08-23-2013, 10:33 AM | #5 |
Newbie Join Date: Aug 2013 Location: Norway
| Re: Turnigy Accucel-6 brokem. HELP-ME
Did you only replace this Power FET, and got the unit to work again? Im asking because the same IC broke on my charger. Its a newer version, with another similar IC. I have my own thread about my problem on rcgroups.com (Sorry for bumping a 3 year old thread) |
08-23-2013, 10:58 AM | #6 |
He hasn't logged on in over 5 months. You might want to try emailing him.
08-23-2013, 11:27 AM | #7 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
OP will surely deliver!
10-19-2013, 11:01 AM | #8 |
No luck on getting a response from the thread creator, but I change the IC with "IRF7413PBF" as suggested above. Charger is now working again. (Pictures in the rcgroups.com) |
