10-08-2009, 10:36 AM | #1 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| super power problems.
just got my 1st super,running 2 esc one for frnt & one for rear. the rear kicks in before the front?? why? how do i fix it. thanks |
10-08-2009, 10:49 AM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Could be radio programming (don't know what you have), could be motor timing (one is set different than the other), or it could be your speed controls are set up differently (don't know what you are using or how programmable they are).
10-08-2009, 10:52 AM | #3 |
radio- dx3r just threw on 2 esc's i had, just stock ones, axial,tekin. will check timing. |
10-08-2009, 12:11 PM | #4 |
Rock Crawler Join Date: Feb 2008 Location: UK
Are you running both ESCs from the same channel (using a Y lead) or are you using 2 separate channels?
10-08-2009, 12:53 PM | #5 |
Im using a y harness. should i go to a 4 ch? |
10-08-2009, 01:04 PM | #6 |
A Y harness is OK, but you obviously can't control the ESC independently. Using 2 different models of ESC makes things complicated, as the throttle response will be different. You could try re-calibrating both ESCs. If it still doesn't work properly, disconnect the ESC that comes on first. Power up again, and squeeze the throttle until the ESC that's still connected starts to drive the motor. Back off again until it stops, and hold the throttle at EXACTLY that point. Re-calibrate the ESC. Hopefully, it'll pick up the new neutral point. If it still doesn't work (maybe the lag got worse), try doing it the other way around. What you are trying to do is synchronise the ESCs by fiddling where each ESC thinks the neutral point is. |
10-08-2009, 01:05 PM | #7 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
10-08-2009, 01:29 PM | #8 |
yes, im running two different speed controls. axial,tekin. all i had at the moment. |
10-08-2009, 01:54 PM | #9 |
Hateraide Join Date: Dec 2008 Location: Mission BC
either ditch the axial the and get another tekin or just run the one tekin
10-08-2009, 02:10 PM | #10 |
Then the only choice you have is to try what clockworks is saying. Both speed controls are going to have a different neutral settings. Maybe try swapping the speed controls around to where the front pulls a little more......... |
10-08-2009, 05:23 PM | #11 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
If you are running off one channel then I would just run 1 ESC.
10-08-2009, 07:19 PM | #12 | |
No point in using 2 ESCs unless neither one can handle running both motors on its own. If you are powering the front steering servo off one ESC and the rear steering servo off the other, then when you go to one ESC you will need a BEC. It would be better to get 2 BECs and use them to run the steering servos. | |
10-12-2009, 09:32 AM | #13 |
fixed problem,just swapped it over to my dx6i,for independent use of the axles. its gonna take sometime getn used to. thanks guys for the help. |
