Thread: Novak M2 Dig ESC Combo
Old 10-12-2010, 07:04 PM   #301
Can I use a DX3S?
Monstergt is offline   Reply With Quote
Old 10-12-2010, 08:04 PM   #302
No it only has a 2 position 3rd channel.
xr__10 is offline   Reply With Quote
Old 10-12-2010, 08:05 PM   #303
Are they out yet
kasper is offline   Reply With Quote
Old 10-13-2010, 03:31 AM   #304
Looks awesome charlie i cant wait to get mine wired up and out on the rocks I also like the lexan strip idea with the led's i had been wondering where to mount mine.
This is mine so far am still waiting on servo and receiver
English Steve is offline   Reply With Quote
Old 10-13-2010, 06:07 AM   #305
Originally Posted by Monstergt View Post
Can I use a DX3S?
With the DX3S, you could use it with only 2 postions (such as 4wd and front dig).
If you really want to use all three positions, you could get one of my 2-position to 3-True-Position adapters at www.wantAsummit.com. I made this to work with my DX3.0 which, just like the DX3S, only has a 2-postion switch.
wantAsummit is offline   Reply With Quote
Old 10-13-2010, 06:31 AM   #306
"HOLLYWOOD"
Mini's Avatar
Do you have a pic of it not all bunched up? Sorry for being picky lol just wanted to see what it look like.
Mini is offline   Reply With Quote
Old 10-13-2010, 07:56 AM   #307
I havent at the moment but will be taking it out tonight when i get home to sort all the wiring so will take a few then
Old 10-13-2010, 08:34 AM   #308
"HOLLYWOOD"
Mini's Avatar
Thank you
Old 10-13-2010, 12:41 PM   #309
Default Iran mine with out a bec for about 2week with no problem.
MR.VERTICAL is offline   Reply With Quote
Old 10-13-2010, 12:41 PM   #310
Old 10-13-2010, 01:29 PM   #311
hope this helps
Old 10-13-2010, 01:56 PM   #312
"HOLLYWOOD"
Mini's Avatar
hope this helps
Very nice! Can you adjust with the on & off button like on most Novak stuff or do you need the cable?
Can't wait to see a vid of it working.
Old 10-13-2010, 02:03 PM   #313
Yes you can along with the Novalink which i havent got yet
Old 10-13-2010, 02:06 PM   #314
"HOLLYWOOD"
Mini's Avatar
Cool
Old 10-14-2010, 01:26 PM   #315
Ok i came up against my first problem. Ive never really understood the flashing light setup with esc's and ive got a little confused setting it up so im going to have to pick up a NovaLink to help me set it up properly. Not a real problem with the esc im just used to the castlelink and hotwire to set up my esc's
Old 10-14-2010, 01:52 PM   #316
ruffryder is offline   Reply With Quote
Old 10-14-2010, 02:30 PM   #317
Sweet! In a esc this complicated....The easy stuff is causing issue's already...That instills allot of faith, woot. lol
meffie is offline   Reply With Quote
Old 10-14-2010, 02:32 PM   #318
They'll get it worked out. I'll probably still get one in the future.
On a positive. Without wires (that are honkin' huge), it weighs 0.3 oz less than two fxr's.
Szczerba is offline   Reply With Quote
Old 10-14-2010, 02:47 PM   #319
"HOLLYWOOD"
Mini's Avatar
Did the box came with instructions??? It should explain it there cause then they are forceing the people too buy that cable.
Old 10-14-2010, 03:35 PM   #320
The setup, and the changing of the settings is fairly strait forward.
Manual comes with a Flow Chart so you "know what's coming".
So far, we have simply Changed to the Biasing Profile, turned up the Drag Brake, and the Dig Power. Takes about 1 minute to go through it.
Takes my PC longer then that to "Turn On". Not sure on a time frame for the M2 NovaLink software, I've tested it once, and it seems to function and work fine. Just have to dedicate some time to sit down and go through it more closely.
One touch setup is easy as any other Novak ESC, it is followed by a one touch setup for the dig switch on the Radio. Takes 15-20 seconds.
After the one touch is completed, you can then change profiles, and adjust settings with the button/led. As it stands at the moment, I don't really see a need for the PC interface unless "that is just your thing".
Novak has always tried to ensure that the ESC doe not "require" the PC stuff to make it work correctly, or even to be able to adjust it. We shoot for as much button adjustability as the PC, the PC generally offers finer adjustments.
Charlie is offline   Reply With Quote
