Thread: Novak M2 Dig ESC Combo
Old 11-05-2009, 06:29 AM   #41
Novak Two did say here they were testing for 3S...
megacabcummins is offline   Reply With Quote
Old 11-05-2009, 07:23 AM   #42
Can this work with a Sanwa M11 - 4 channel receiver ( Sanwa Spektrum )
Also kindly note that we will be setting the crawler with 4 wheel steering.
Hope it can works since i think that the 4 channel has only an on / off mechanism :(
but i am not sure.
Thanks
speed6 is offline   Reply With Quote
Old 11-05-2009, 08:09 AM   #43
"HOLLYWOOD"
Mini's Avatar
Saying it and making it OFFICAL are 2 different things. That;s the only thing hold me back from pre-ordering one right now when the spec sheet on the website says it, it's a done deal.
I just don't see a Moa running to it's full potential on 2S that's why you sell all these guys running 3S.
Mini is offline   Reply With Quote
Old 11-05-2009, 11:27 AM   #44
I will be trying one out when acailable i will use a 3s lipo and will add a external bec as well its only money however they are testing it with a 3s i saw it work at i hobby and its very simple to use i think this will be a great product it makes the rest of the companys to step up there game.
kasper is offline   Reply With Quote
Old 11-05-2009, 08:32 PM   #45
Originally Posted by Charlie View Post
I had a chance to operate the M2Dig for 4 whole days while I was working the Novak Booth ath the I Hobby Expo last week.
While I didn't have a chance to get out on the rocks with it, here's how it works, and works well in my opinion.
You shoulda brought it over to our course. We woulda let you run it there! Hell we let himoto run.. err...umm... try!
addictedtonitro is offline   Reply With Quote
Old 11-05-2009, 10:14 PM   #46
Yeah, I talked to Steve today. They are still testing the M2 Dig on 3s.
I am going to get on either way like Kasper said. 3s and a CC BEC......we will find out.
Rockcrawler is offline   Reply With Quote
Old 11-06-2009, 03:56 AM   #47
but i am not sure.
Thanks
bumb
Old 11-06-2009, 07:48 AM   #48
"HOLLYWOOD"
Mini's Avatar
AAAWWWWWW the perk's of being a sponsored driver direct contact with the BIG DOGS
Just noticed this setup does not come with a built in BEC sweet now I can see the light at the end of the tunnel CC BEC here I come
Rockcrawler will you still run your 35T on this setup or go bigger?
Old 11-06-2009, 10:19 AM   #49
The copy says 6 Volts/5 amps BEC.....
NovakTwo is offline   Reply With Quote
Old 11-06-2009, 01:10 PM   #50
"HOLLYWOOD"
Mini's Avatar
My bad your right I was reading the features not the specs and the world BEC did not show up sorry about that.
So with the Novak Link will we be able to bump up the volts to the BEC?
Old 11-09-2009, 05:26 PM   #51
"HOLLYWOOD"
Mini's Avatar
so any word on this yet?????
Old 11-09-2009, 05:44 PM   #52
I am not sponsored in any way by Novak.
I will be running the 35t Chrome cans from JPCustoms as soon as I get my hands on one.
As far as the BEC goes, you need to run a BEC on every ESC out there with the exception of the one from JRH. When you put these ESC's on 3s, it heats everything up too much when trying to run a high torque servo.
(Not talking about Novak here)
Everyone keeps saying that the QC is getting worse from all these top companies. Its because everyone is running them on 3s, not because of QC or bad parts. I know a few ESC's with bad parts have gotten out, but not in the quantity that we are seeing on the forums.
Old 11-09-2009, 09:06 PM   #53
"HOLLYWOOD"
Mini's Avatar
Thats what I was thinking eaither way you have to run a BEC to your steering servo atleast if you run Novak ESC since it comes with a built in BEC you can't run to BEC togethers unless you pull the signal wire from the ESC like CC say's on the instructions.
How would you run it Rock?
Old 11-09-2009, 09:18 PM   #54
I personally let the ESC power the receiver. I just run the BEC wires straight to the steering servo. Go buy a Y-harness. Take the 2 female ends and shorten them and wire them together (just the 2 female ends). Use that to plug the BEC and the servo into. This way you dont have to solder or cut servo wires. Take the spare male end that you cut off the y-harness and put your signal wire into it. Then just plug that into the receiver.
Old 11-10-2009, 06:23 AM   #55
So why not just use the onboard BEC? If it runs 6v why would you not use it? Just curious...
Old 11-10-2009, 08:24 AM   #56
Technical questions, email tech@teamnovak.com for a response.
Old 11-10-2009, 09:17 AM   #57
"HOLLYWOOD"
Mini's Avatar
Thats how I have my shafty wired Love it!!
Old 11-10-2009, 09:19 AM   #58
"HOLLYWOOD"
Mini's Avatar
You just said it 6v that's all you get with the CC BEC you can but it higher. And also installing another BEC your ESC will run much cooler.
Old 11-10-2009, 04:01 PM   #59
It's not so much about volts, but amps. The castle is 10 amps while the novak is 3 amps. The big servos we run on crawlers can pull way more than 3 amps in a bind, causing all kinds of problems.
oldhippie is offline   Reply With Quote
Old 11-10-2009, 04:10 PM   #60
MODERATOR™
EeePee's Avatar
5 amps according to them. Which powers my 423 ounce servo and dig servo just fine with out any outboard help.
Granted it's with a 2S and 13.5 motor, but still. No problems.
EeePee is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
