10-23-2009, 11:28 PM | #1 |
Newbie Join Date: Jun 2007 Location: Central NJ
| help setting reverse with Spectrum fx3r
I am using tekin fxr with spectrum dx3r. New to this radio and trying to setup reverse. Tried everything on esc but nothing worked. Are there any mechanical setups on transmitter which enable the reverse trigger ? I also saw under "monitor" screen that when I press the throttle for reverse, screen does not show any movement however +ve throttle shows the bar move. Please help
10-23-2009, 11:41 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
Check and make sure the travel on the transmitter is not set to 0% for reverse.
10-24-2009, 10:05 AM | #3 |
travel is set to 100/110
10-24-2009, 10:14 AM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
did u buy the radio new or used?
10-24-2009, 10:31 AM | #5 |
| used
came with the truck used. It looks fine to me. like tq3, are there any trigger adjustments ?
10-24-2009, 10:40 AM | #6 |
You can download the manuals for both online. Maybe try re-binding it... |
10-24-2009, 01:30 PM | #7 |
Rock Crawler Join Date: Feb 2008 Location: UK
If the bar doesn't move on the monitor screen, it's definitely a Tx problem. Most likely it's a setup problem - try changing to a blank model memory, and see what happens. |
10-24-2009, 01:39 PM | #8 |
ok got it. go to the menu options and to sub trim, make sure the trottle is set to 0, then on the main screen use then set the brake to about 80% (this may very depending on what ecs u ahve and how you have it programed) what button does the depends on what its set to, mine is "E" this was the only way i could get the bar not to move- having the sub trim set to +100% and the brake turned down to 0... out side of that reset the modle memory and start from scratch Last edited by ultimate_monkey; 10-24-2009 at 01:42 PM. |
10-28-2009, 10:01 AM | #9 |
| Now Aux channle issue
Thanks for all the help. I got it working in reverse but now the Dig channel won't work. As per a post here somewhere, I setup Aux curve to 40% 40% and assigned D E and F buttens but it does not move at all. Checked the servo and it is in good shape. When I go in bind mode, dig servo keeps twitching however once the bind is complete, AUX channel does not work. Any pointers ?:-( |
