10-26-2009, 01:33 PM | #1 |
Newbie Join Date: Apr 2009 Location: Houston
| ESC / Receiver Placement
Getting ready to place my electronics in my rig. See where my BEC has to be min 2" away from receiver....what about the receiver and ESC? I have a ESC shelf and would like to have the ESC on the top and radio reciever mounted upside down on the bottom. Any reason why this might not be a good idea? |
10-26-2009, 03:18 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Why does your BEC have to be mounted 2" minimum from your receiver? I have a Castle BEC attached to the side of a Tekin FXR ESC, which is mounted right next to a 2.4GHz receiver, and I have no problems with the setup. The RX antenna is routed along the chassis and away from the ESC. |
10-27-2009, 08:10 AM | #3 |
Not sure why the req. Running a SportBEC from Dimension Engineering and it states the min distance in the install guide. That is why I am wondering about the ESC too...cant find any distance req's...but thought I would check with the broader community. |
10-27-2009, 08:17 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
The Castle BEC has a notation regarding RF Noise: This device should be treated much like a speed control. Try to keep as much distance as possible between the radio receiver and components and the CC BEC unit. |
10-28-2009, 02:51 PM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
ESCs and some, if not all BECs emit radio waves (noise), and of course your RX likes to receive radio waves. Manufacturers can't test every possible ESC/RX/BEC/Motor... combo out there so they make these statements so you have the lowest chance of having issues. When I had a Sidewinder, CC BEC, and old 72 MHz AM RX I couldn't stop it from glitching even though the ESC and BEC were > 2" away from the receiver. I ended up going to a FM Rx to fix it. Point is, try what you prefer and if it works have fun. If it doesn't try something else. Just make sure your truck doesn't fly off the workbench! Richard |
