12-02-2009, 12:27 PM | #1 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
| No throttle?
Ok so I am a bit stumped and wonder if the FXR in my berg is dead? Over the holiday I was crawling over some rocks in the back yard to show the bother in law and family what a berg could do. When I went to charge it the next day the voltage was low on the 3s Lipo, but the battery had not swelled ( I did not leave the battery hooked up). I have heard rumors that FXRs can re-set to default (i.e. no low voltage cut off)???. Anyways I have since swapped out the receiver from a modd'd TQ3 with three pos switch to a EX-5UR. While I did this I re-set the 9 volt cut off on the FXR and made sure that the no-brake, instant reverse was locked in. When everything was done I tried the controller and I have steering and 5-pos dig servo action, but no throttle forward or backward. Is the FXR done? what should I do to see what's going wrong? Any ideas? ....also I then broke off the capacitor trying to get a look at the FXRs LEDs while I was checking the FXR afterwards so I will need a new one of those before I can do any diagnostics on the FXR.... Any one know where I can get a replacement capacitor for this potentially dead speed control.... I am also wondering if the capacitor was damaged before this because I had to move it to see the LEDs on the FXR and the connection could have been broken as a result of this....????? Thanks |
12-02-2009, 03:10 PM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
I would check to make sure the esc plug is in the right way in the receiver. I have done this a few times changing receivers. How low was the voltage on the battery? I would not think it was the battery though. If the receiver is in right, swap the radio back out....could be a bad receiver. You could also swap out the steering and throttle in the receiver....just have the truck off the ground in case it takes off. |
12-02-2009, 03:20 PM | #3 |
I should have checked the battery first. it was below 9 volts after it took a charge. I guess a cell is dead. I killed a Lipo. now I wonder why the FXR did not cut it off when the lipo hit 9-volts the first time?
12-02-2009, 03:39 PM | #4 | |
It could have reset for some reason like you said earlier. I usually check my settings on my FX-R every month or so just in case. I have never had it lose my settings, but dont want to chance it. | |
