Help with a TQ3 Do i need 2k pots or can i use the 1k pots from Radio Shack? I am not sure of the difference. I found a thread here where i guy used the 1k pots but others say you need 2k pots. Also, i there a way that i can run the stock red switch for front dig(That is the common one used where the back tires are locked and the front truns.....right?) and then have a 3 position switch for everything? |
I used 2k ohm pots on the one i did a while back.. |
People use 2K pots because they are easy to find. 1K pots will work for most mods. You could wire the red switch in parallel with the 3-position - just make sure you don't turn both switches on together. Not a problem if they are both set the same way, but could be a problem if they are set opposite ways with the pots turned down to zero. |
