12-13-2009, 02:33 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: backwoods of ny
| noob wants to know..
okay heres the set up-- tekin fx-r esc w/45t motor cc bec and hi-tec 645 servo.. am totally new to crawlin and would like to know what size lipo would give me great run times, and be able to get wet and muddy?? dont dog me guys i am totally new and really want good advice..:?
12-13-2009, 05:53 PM | #2 |
Rock Stacker Join Date: Oct 2007 Location: Stevensville
I run a 2cell lipo which is 7.4 volts I get about an hour+ run time, remember your going slow,so your not drawing that much . You can get them wet and muddy... STAY far away from salt water that will kill it!
12-13-2009, 06:11 PM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Depends on how wet and muddy you're talking. If you want it absolutely waterproof, Max Amps has them. Otherwise, be cautious and dry everything out as soon as you can. And you should have all the electronics in a box if possible, the FX-R and most other ESC's that are not waterproof will cook if they get wet. Maybe not right away, but it will happen. Run time...for reference I'm getting 40 minutes on Holmes 3s 1300 packs with a 45T, 7955TG servo, 5245MG dig servo, and an FX-R. |
12-14-2009, 08:04 AM | #4 |
Newbie Join Date: Apr 2005 Location: holloman
I would avoid getting a lipo wet unless it is one of the sealed maxxx amp deals, if you want it to get wet and muddy just pick up some nimh cells, and like bigsky said because the trucks are geared low and the high number of winds the current draw from the motor is low and even cheap sport packs can give you decent run times. This is a part of rc where lipos really aren't needed, the biggest bonus we get is weight savings.
12-14-2009, 10:22 AM | #5 | |
Weight savings is only a small part of the equation. More power, longer runtimes with smaller mah's, and the consistent power output from beginning to cutoff are what really make them way better than NiHm, besides weight. 35T is the norm nowadays for motors, with 20-25T for those of us who are more power hungry, or big Cobalt Puller motors for sheer brute strength. Mcreil41, with your setup anywhere from 1100mah(probably 30-40 mins) to 2200mah(several hours) of runtime depending on throttle usage. I really like the 1700mah 3cell and the 2200mah 3cell packs from CBP. http://www.cheapbatterypacks.com/ind...CFEB3&sid=6021 smaller 1300mah packs http://www.cheapbatterypacks.com/ind...AD856&sid=6021 Last edited by Tanis; 12-14-2009 at 10:27 AM. | |
12-14-2009, 02:23 PM | #6 |
Quarry Creeper Join Date: Oct 2009 Location: stephens city
i have the fxr with the 35t and run a venom 1320 mah 3s lipo and get about hour out of it got from tower for like $20
