01-10-2010, 05:32 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: backwoods of ny
| castle link question..
i will be running a tekin fx-r w/35t motor,and using a hi tek 645 servo. and a castle creations bec,now the question is - will i need to get a castle link to program the bec or will the stock settings work?? i will definitly be running lipos...i have read and read and just need to get it straight...:?
01-10-2010, 05:38 PM | #2 |
if you want it to put out 6v you will need a castle link but if 5.1v is ok with you you dont need a cc link
01-10-2010, 05:39 PM | #3 |
the BEC is set to 5.1v output from Castle. If you want your servo to get more than 5.1v then yes, you'll need the castlelink to reprogram the output voltage. I just bought it last week and changed all mine to 6v output. except for the berg with my new Hitec 7950TH, set that bec to 7.0v |
01-11-2010, 07:53 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: minnesota
Can always order the CC BEC from a vendor like Holmes Hobbies and have them program it for the voltage you desire....having the castle link is very handy if you have a couple of Castle's products however... |
01-11-2010, 09:39 AM | #5 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
x2 Yeah, I would hate to spend the extra money on a castlelink if all you have is the bec. The link cost as much as the bec itself. Like weck said, you can order it pre-programmed for desired voltage or you can stick with the 5v |
