Thread: ~~Evx-2 question~~
Old 01-12-2010, 02:03 PM   #1
Arrow ~~Evx-2 question~~
ok im plannign on get a traxxas evx2 and putting a jumper on the none BEC side, But i was just wondering it is possible to put a jumper on one of the motor leads so all the power is put into only one motor. Possible or Not??
73formulabird is offline   Reply With Quote
Old 01-12-2010, 02:14 PM   #2
i doubt u can jump them together w/o damaging it. just hook up one set of leads to a motor and all the power will go to it. But wats the point of having an evx2 if u are only running 1 motor and 1 battery? why not just a normal esc?
benoj is offline   Reply With Quote
Old 01-12-2010, 03:20 PM   #3
Yes, this is how the Summit is wired.
http://www.traxxas.com/PDF-Library/5610_manual.pdf
Look at Pg 9.
Greatscott is offline   Reply With Quote
Old 01-12-2010, 04:13 PM   #4
the summit doesnt use a jumper just both sets of leads plug into the motor as it has 2 of each wire. just tuck the other set away
