Thread: Cutting a motor commutator & motor tweaks
Old 02-16-2010, 03:34 PM   #41
MODERATOR™
EeePee's Avatar
Originally Posted by Rockcrawler View Post
Oh, and Rob, not trying to be a know it all.
Quit being an ass.
EeePee is offline   Reply With Quote
Old 02-16-2010, 03:37 PM   #42
Originally Posted by EeePee View Post
Quit being an ass.
NEVER!
Rockcrawler is offline   Reply With Quote
Old 02-16-2010, 03:38 PM   #43
Good stuff, just broke out my old motor rebuild gear from back in the carpet oval days. Rebuild 2 Integy motors for a guy I crawl with. Took me a while to remember all of the tricks I learned from the past. I relay miss building motors. That was part of the hobby for me. Now with all this brushless stuff coming out... Blah. These new guys don't know how easy they have it! Same thing goes for batteries! Discharge trays, dead shorting the battery, Raising the voltages. All of it was a lot of work! Now just get a brushless setup and a lipo and go to the track.. Its not the same!
prophetz is offline   Reply With Quote
Old 02-16-2010, 03:41 PM   #44
No, its not. But brushless is headed in the same direction now. They are about to release (if they have not already) rebuild-able motors......they are putting them on dyno's now also.
I started this hobby racing carpet oval.
Old 02-16-2010, 04:25 PM   #45
Custom Carbon Fiber
Robbob's Avatar
Oh, and Rob, not trying to be a know it all. I am just learning all of this again myself. I have been told that this man knew what he was doing and what he was talking about so I have been "going by the book" on everything I can.
nah but youve got me thinking now lol.
same here, Oval racer at heart myself. if theres a tenth of a second to be saved or 5 more rpms to be gotten an Oval racers is always looking for it
Robbob is offline   Reply With Quote
Old 02-16-2010, 05:50 PM   #46
MODERATOR™
EeePee's Avatar
You nerds talking about aligning the brush hoods with this tool?
I use one of those to get everything together and as a starting point.
Then I do the tweaks to the hoods one side at a time, like I showed earlier in the thread. Rarely have I seen the comm hit the center of the brush using that alignment tool alone.
Oh and yeah, I've serrated some brushes, and not some.
Old 02-23-2010, 12:57 AM   #47
dnf
rock hard's Avatar
ok,this is what I'v been looking for.
I have searched lathes but all I get are larger ones.
where do I find these lathes and all tools needed.
also I assume I can do 380 and micro motors aswell with it?
I think cutting the comms wil be easy enough,but aligning the brushes
sound like it may take some practice.
I really want/need to learn this. but I cant drop 300 for a harbor frieght
micro lathe right now. and thats about the smallest I found.
glad I found this here,rcc freaking ROCKS
rock hard is offline   Reply With Quote
Old 02-23-2010, 01:06 AM   #48
Good place to start
http://www.stormerhobbies.com/cgi-bi...ode=0&showt=on
TEDROCKZ is offline   Reply With Quote
Old 02-23-2010, 01:17 AM   #49
dnf
rock hard's Avatar
damn it man,basically I cant afford it,hell just the cutting tool is around 150
nope not gonna be learning it yet.
anybody want to cut some comms for me? 380 sized
Old 02-23-2010, 01:28 AM   #50
dnf
rock hard's Avatar
Originally Posted by TEDROCKZ View Post
thanks,I will have to wait though.
I like the fantom the best I think.
but not sure yet.
can you break your motor in on em as well?
and will these work on 380's and micro motors?
I assume so,but would like assurance first.
Old 02-23-2010, 11:23 AM   #51
dnf
rock hard's Avatar
ok found a entigy xipp perfect comm lath 2
it says from 180-540 sized motors can be cut.
129 on thier web site
90 new on e-bay
but I cant get muck detail about it.
does it come with the bit/pully's belts,motor ect?
but this is what I'll shoot for I guess since it does 380's
also
is it possibale to remove a comm and replace it with a larger diam. comm?
and if so where to buy the larger comm.
and whats the process of removal ect.
Old 02-23-2010, 12:15 PM   #52
Location: Taylors Falls just hanging with the MNRCRC crew.
Don't forget to search Cobra and Huddy on fleabay but don't even think you can live without a diamond cutter it's a must have IMO.
Stormin2u is offline   Reply With Quote
Old 02-23-2010, 12:31 PM   #53
dnf
rock hard's Avatar
the only hudy and cobra's I see are for 540 sized motors.
I talked to fantom,they said the 380's wont work in a typical comm lathe
the integy is the only one I have found that will do the 540 and 380
but I like the looks of the fantom lath the best.
Old 02-23-2010, 01:41 PM   #54
Norm you are right to an extent. It has been a few years since I even owned a lathe. Mid 90's. Diamond cutters are great but very fragile. For a typical crawler toolbox a carbide will suffice. Now if you are experienced and cut comms on a regular basis diamond cutters are keen.
Bit of info from the master, Big Jim:
Choosing A Bit
First, the benefits of carbide supercede that of a diamond. Here's why. If you've never used a diamond tool bit before, you will probably chip it before you figure out how to set it up. Then you won't know it's chipped and you'll keep trying and trying and you'll look like Big Jim and Hank by the time you stop pulling your hair out. They chip very easily. Then you're out of a bit of money and have a whole lot of frustration ahead and behind you. Diamond bits are for experienced pit lathe users or machinists. I have been cutting toy motor comms for 30 years and I use carbide bits.
Diamonds can go bad if you take too big a cut, if you hit the tabs, even if it was cutting fine when you packed it away, a diamond bit can be bad the next time you take it out. Don't ask me why. I have even chipped a diamond just by using the wrong kind of brush to clear the chips away. I figured out later that the steel band around the small paint brush I was using must have hit the tip.
And no two diamond bits are the same as far as setup goes. Some bits need no shims. Others of the same brand and type will require 2 shims. Don't ask me why on that either. Carbide bits of the same brand always seem to setup the same. Another reason to use carbide is when it's dull, the finish looks like crap. A diamond will just start cutting out-of-round and you won't know it until your start putting your motors together because the finish looks fine.
Unless you are extremely experienced, stay away from diamond bits. Use carbide until you gain that experience. Then you can either buy a tool sharpener like I did to do the job right, keep honing the tip with a diamond file until it is so distorted it (you unintentionally change the angles a little each time if you won't work anymore then sharpen by hand), throw it away and start with a new $4 bit or use a diamond. Here's the tool sharpener I use. I've had it since 1980 and it still works fine. www.glendo.com.
Old 02-23-2010, 05:33 PM   #55
I use carbide bits all the time. Get the cheapo set of them from Harbor Freight, just swap the tips around or replace them when they start cutting poorly. Diamond is nice, but not necessary.
Search the rctech.net classifieds for used comm lathes.
Needing to cut 380 motors will really limit the selection, as you have found.
Manning is offline   Reply With Quote
Old 02-23-2010, 05:45 PM   #56
Originally Posted by EGRESSor View Post
it runs to hot
i like the P94 brushes or the Kyosho 5x5 more
I also like the P94s I wish they were easier to get though...
killswitch is offline   Reply With Quote
Old 02-23-2010, 05:49 PM   #57
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I have a huge pile here if you need some
Great thread. Not much I can add to it really, you guys already know the tricks
JohnRobHolmes is offline   Reply With Quote
Old 02-23-2010, 08:03 PM   #58
dnf
rock hard's Avatar
hey man.pm me. I need to talk to you about 380's
if you notice nobody really has any advice on the 380's
Old 02-28-2010, 12:21 PM   #59
MODERATOR™
EeePee's Avatar
This is a nice looking motor, I'll have to see if I can drag this out long enough so the guy will forget he gave it to me to tune up.
Yokomo based 12 turn double, laydown brushes, four magnet can, perfect for flooring it in the scaler!
Old 02-28-2010, 01:50 PM   #60
Looks like your having fun EP. I got my little cobra lathe in Friday evening, now I'm going through old storage bins, closets, shelves, etc... hunting motors to tinker with. Cut on them first to get the hang of it again before I start cutting all the high dollar handwounds.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/223989-cutting-motor-commutator-motor-tweaks.html
Posted By For Type Date
Hiilimoottorin kunnostaminen This thread Refback 10-04-2011 03:19 PM
