Thread: Cutting a motor commutator & motor tweaks
Old 03-11-2010, 06:36 PM   #121
Originally Posted by killswitch View Post
I have used and owned other lathes over the years and I really like the Hudy stuff. I had a manual one that I scored in a trade during my last spin with carpet racing and it was really nice and a friend had the automatic one that was really nice. At one time I had a trinity lathe that used bearings instead of V blocks and it was great until the bearings started wearing out. I wouldnt get a consistent cut because the arm and bearings would float a bit due to slop. I dont think Ill ever go back to that style.
Yeah, I have a hudy with the worn bearings......going to order the V-blocks when I get a little extra cash. I like it because it will cut the puller comms.
Rockcrawler is offline   Reply With Quote
Old 03-11-2010, 06:37 PM   #122
Originally Posted by IDnewcrwlr View Post
cool, i guess what i should have asked is is there one in particular that i should try and grab up over another?? i would like to spend no more than 150 IF possible. .. . thanks for the reply. ima have to check out that rctech NOW
You can get most of them for around $50 now that brushless has taken over the onroad racing. I did pay $100 for my Hudy but should have waited a little bit for the price to come down.
Old 03-11-2010, 07:40 PM   #123
There are several on the Bay right now, a couple of good deals
TEDROCKZ is offline   Reply With Quote
Old 03-15-2010, 07:10 PM   #124
Well, I am about half way through reading Big Jim's RC Motor Black Book. I was getting a little bored with it at first because it was going through all the basics. Its starting to get really good though. Learning some stuff that I didn't know, and a lot of important stuff that I had actually forgotten about.
If you don't have one of these books, I highly suggest you pick on up if you are serious about taking care of and getting the most out of your motors.
After just the first half of the book, I am curious as to what I can do even with a Integy motor now that I know what causes the loss of torque in most of them. They will spin up OK (RPM) but not much torque.
When I get some time at home...........Its on with the dyno and lathe.
Old 03-15-2010, 09:20 PM   #125
MODERATOR™
EeePee's Avatar
Gimme three examples.
EeePee is offline   Reply With Quote
Old 03-15-2010, 09:43 PM   #126
I will give you one.
And I CANNOT believe I forgot about this........
Most of the current runs through the brush hoods, not the shunts. The shunts them selves are only rated at 10 amps.
Back to reading.
Old 03-15-2010, 09:44 PM   #127
MODERATOR™
EeePee's Avatar
That's why you need clean brush hoods and brushes.
Old 03-15-2010, 09:46 PM   #128
That's why you need clean brush hoods.
Yep.
I think I am going to tear down my motors after ECC and go through them completely. Run them on the dyno and find the sweet spots.
Old 03-15-2010, 09:48 PM   #129
Back to reading.
Some brush manf. come out with a twin shunt brush(parallel) but still sucked.
Also
Old 03-15-2010, 09:49 PM   #130
MODERATOR™
EeePee's Avatar
After?
Before.
And, ha!
Old 03-15-2010, 09:52 PM   #131
Also
Yeah, they still only handle 10A though......just a gimmick more or less.
And You damn right.
After?
Before.
And, ha!
Got to get a new bit before I start cutting new motors......broke right now.
Old 03-15-2010, 09:53 PM   #132
Come on JRH.......I see you peaking in.
Anything to add?
Old 03-15-2010, 09:57 PM   #133
I'll send you one tomorrow.
Old 03-15-2010, 09:58 PM   #134
THANK YOU!
Well, looks like I might have some fresh tuned motors for ECC then.
Old 03-15-2010, 09:59 PM   #135
Still takes a little while to read...
I am on page 100 though.
Also
Old 03-15-2010, 10:03 PM   #136
They are hard to find, saw one go for $130 a couple of weeks ago. Also the OG tools are hard to find. I did manage to find one of Jims Sonic Fiddle sticks and a set of his hood alignment tools, after many hours of surfing. Also looking for some of the Parma Comm cleaning sticks, no luck on those
Nif-tech and Muchmore Racing has some cheaper versions.
Old 03-15-2010, 10:06 PM   #137
Didnt know they were that high.
Yeah, I am going to order the Racers edge ones and try them out.
Old 03-15-2010, 10:19 PM   #138
Anyone looking in ever try these. Found them on the Bay for a buck per set. Picked up 14 sets. The OG listed for 12-14 bucks at one time. I'm not really familiar with them.
Old 03-15-2010, 10:21 PM   #139
Attachment 129418
I thought the more silver in the brush, the more wear?
Unless they mean comm wear..........
Old 03-15-2010, 10:27 PM   #140
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You are correct. More silver makes brushes wear faster.
You have email btw.
JohnRobHolmes is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/223989-cutting-motor-commutator-motor-tweaks.html
Posted By For Type Date
Hiilimoottorin kunnostaminen This thread Refback 10-04-2011 03:19 PM
