01-25-2010, 10:37 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: columbus
| does anyone make a servo with less throw?
I have a hitec 645 working the disconnect on my R2 trans and it has to much throw and puts the disconnect shaft in a bind and it don't want to go back in gear all the way. I have tried using different lenght servo arms with no luck. I have a shorter arm on right now and it seemed to help a little. I need a servo with very little throw if anyone makes one. When I go to disconnect the trans the linkage pushes downward on the disconnect shaft and puts in a serious bind. It should move in and out smoothly and straight in and out ,but instead it puts pressure on the disconnect shaft and pushes it downward. Any help with this would be greatly appreciated. Thanks.
01-25-2010, 10:58 PM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: Concord
Just use a radio with end point adjustment and be done with it
01-25-2010, 11:00 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Get a radio where you can adjust the endpoints.
01-25-2010, 11:11 PM | #4 |
01-25-2010, 11:16 PM | #5 |
Endpoints are digital. Trim is just adjusting the frequency, which what the TQ3's adjustments are.
01-26-2010, 12:16 AM | #6 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
read the tq3 mod thread. You can install some adjustment pots to limit the travel.
01-26-2010, 12:22 AM | #7 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
01-26-2010, 02:08 AM | #8 |
Rock Stacker Join Date: Nov 2009 Location: Europe
if you dont fancy modding your radio, have a look at this.. http://www.servocity.com/html/180o_servo_stretcher.html |
01-26-2010, 04:49 AM | #9 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
I just bought a 3pm-mx because my old radio was lacking adjustment.....best $180 I have spent!!!
01-26-2010, 05:14 AM | #10 | |
01-26-2010, 07:13 AM | #11 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Or buy a Hitec programmable digital servo and using one of their servo programmers, reconfigure the endpoints to achieve reduced throw. You might be able to get your LHS to do the programming for you no charge. Narly1 |
01-26-2010, 08:15 AM | #12 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
another simple option is to use a shorter servo arm. |
01-27-2010, 02:14 PM | #13 |
01-27-2010, 04:08 PM | #14 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
instead of a solid link, use some shift linkage from a nitro as the connecting arm. The springs will let the arm go farther than needed. Here's my old dig setup, when I didn't have EPA's just a 645, shift linkage, and some collars. Home fabbed since this was before everyone could buy one. You can use pen springs if needed to adjust tension. I used this dig for a whole season with no probs at all. The springs also let everything line up before tension is fully applied. |
