Thread: Little bit of a problem, Possibly big problem...
Old 03-05-2010, 08:21 PM   #1
Default Little bit of a problem, Possibly big problem...
Ok so today I was running my SCX 10 with my Goat 3s and a 9100t and how the thing is awesome. but at the end of my run i had a few problems.. First the goat started to twitch not go and the go really jittery, It did it out of the box but I mess with the sensor wire and its fine, but this time nothing seemed to help. So I dont know..
Then the servo started acting up, I would turn the wheel to the right and it would go right then left then right again with out me doing anything but holding it to the right.. Now when I plug my battery in it goes back and forth to the left and right un controllably and I have no idea what is going on.
C_Money is offline   Reply With Quote
Old 03-05-2010, 08:26 PM   #2
interference somewhere, or maybe need a bec? double check where the sensor wires plug into each other but be gentle cuz i ripped one of those lil bastard wires right off the circuit board
liverkiller1 is offline   Reply With Quote
Old 03-05-2010, 08:42 PM   #3
I have the servo hooked up to the CC BEC at 6v.. Not sure where the interference could be coming from cause it worked fine for most of the day.
Old 03-05-2010, 09:43 PM   #4
Is the battery low?
JeepinDoug is offline   Reply With Quote
Old 03-06-2010, 12:28 AM   #5
I will check it tomorrow, it shouldnt have been. I know the goat has auto cut off. But maybe thats it.
Old 03-06-2010, 02:49 PM   #6
Battery was at 6.3 volts, hope I didnt hurt it. But that was probly the problem.
Old 03-06-2010, 03:04 PM   #7
what battery were you running??? 2s should be fine down to 6 volts, however if your running 3s its junk.
Sharkey is offline   Reply With Quote
Old 03-06-2010, 11:00 PM   #8
its a 2s, I thought it was good to 6v.. Its the holmes hobbies 2s 1300mah
Old 03-06-2010, 11:05 PM   #9
What radio do you have? Did you install the included BEC and how?
indiana mudcat is offline   Reply With Quote
Old 03-06-2010, 11:13 PM   #10
If your electronics are higher quality and your battery is not, or low C output battery, at 6.x volts and your BEC set at 6 volts what could be happening is the rest of the electronics are taxing the battery.
This means all your electronics are not getting what they need to operate properly.
I bet if you try a good 3s LiPo you will not have any problems.
Also double check your BEC settings and look for the green LED when it's powered.
Old 03-08-2010, 12:22 PM   #11
Whats a good smaller 3s?? I can only fit something about the size of the holmes hobbies in there. thats The battery I am using now, but in 2s.
Old 03-08-2010, 05:49 PM   #12
the hyperion 3s 1100mah 35c is small and packs plenty of punch, or you could get the thunder power 45c. PM Krawlerhobbies or visit krawlerhobbies.com if you don't see what you want pm him and he probably has it.
456heinbach is offline   Reply With Quote
