03-21-2010, 03:24 PM | #1 |
Newbie Join Date: Dec 2009 Location: Baton Rouge
| Clicking Integy?
Is it normal for a 65T Integy lathe motor to click in reverse? I installed one today and noticed a clicking in reverse. I went through the gear train piece by piece looking for the source... I even measured the stock motor and the integy looking for differences in the cans that might affect pinion/spur mesh. Finally, I spun the Integy and noticed that it clicked when spun in reverse! I put power to it while I had it on the bench... Sure enough, it clicks loudly in reverse. Granted, this is a lathe motor and not the "Professional crawling motor". Is this normal and why?
03-21-2010, 07:21 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
I have not heard of that before..........I have a 55T Integy lathe motor and it doesn't make that noise. I would contact Integy if you bought it new.
03-21-2010, 07:45 PM | #3 |
Newbie Join Date: May 2007 Location: R Ken Saw
i bought a 55t that did that it went away after a few packs |
03-21-2010, 08:26 PM | #4 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
Its normal and will go away after a few days.
03-22-2010, 04:35 PM | #5 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
| Yeah, it's normal if you want your commutator to wear out prematurely. If you are so inclined, you should pull out the brushes that are in the motor and look at the end of the curved part of the brushes--they should have a flat/dull edge instead of a sharp edge. You can take the brushes and file them down lightly by holding a fine toothed file flat on a table/bench and taking your brushes such that tips of the curves are both touching the file simultaneously and then lightly run the motor brush across the file in a linear motion. I tell you, with the advent of brushless motors, most people have seem to have forgotten how to properly care for standard brushed motor. When I was racing off-road and touring car r/c's, I would do this procedure after cleaning off the face of the brushes after every run. |
03-22-2010, 06:43 PM | #6 | |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
03-22-2010, 07:21 PM | #7 |
| Clicking Integy
Thanks guys, I put a drop of com oil in the motor, and ran in on the shelf under low power for a few minutes. When I put it back in the truck, it ran noise free!. Thanks for the tip about the file, I'll try that, too.
03-23-2010, 09:54 AM | #8 |
Rock Crawler Join Date: Jun 2009 Location: Colorado Springs
But it also depends on the motor, if its a sliver or black colored one from integy then yes its normal. When I got my 45T and my 55T it did that, and its a silver one. After a few hours of running it goes away, its just the brushes braking in. But if its one of the blue ones they make then I dont know, any of the blue ones I have got always ran quiet
03-23-2010, 11:15 AM | #9 |
Rock Crawler Join Date: Apr 2009 Location: Pa
The comms of the integy motors are known to be way out of wack from new. The comm should be cut before you run them. Got a new 55t on the way, will see how out the comm is.
03-23-2010, 05:16 PM | #10 |
Rock Stacker Join Date: Aug 2006 Location: webster
I had this problem and it ended up smoking the motor later. The brushes in it were not curved but were flat rather. It's dumb becasue what i figured out was the problem was was that the brush hoods were to big for the brushes and the brushes wiggled around. If you have one laying aorund try throwing your armature in an old epic can or something. It solved all the problems and got a noticeable amount of power
03-23-2010, 06:17 PM | #11 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
The Integy motors really need to have the comm trued and a quality set of brushes thrown in it at the bare minimum. If you want it to run good (well, as good as an integy motor is gonna) you have to line the brush hoods up and re-shim the arm so that its in the center of the magnetic field. Those motors are just thrown together in a factory and really can benefit from a simple tune up. Check out Eee Pee's thread about cutting comms theres tons of quality info in it and none of the work is really difficult. If you dont own a lathe there's sure to be a local racer that still has one and will probably cut your comms for a very minimal fee.
03-23-2010, 07:44 PM | #12 |
not alot of people racing still have lathe's. and if they do they probably don't have a bit for it's that still very sharp. with all the new brushless technology out there the racing scene is almost purely brushless
03-23-2010, 07:51 PM | #13 |
The racing scene is brushless now, but racers are racers. Especially older touring/12th/oval guys. They still have the gear sitting at home instead of being lugged to the track every weekend. I know of at least 6 guys I used to race with that still have all of their brushed motor stuff, even though they all now race brushless exclusively. Ive even bought a ton of can/endbell setups from some of them. Ask at your LHS if they know anyone that has a lathe. I still make $$ from my lathe thanks to my LHS... anyone at all that asks about brushed motors and tuning them gets pointed in my direction.
03-23-2010, 08:13 PM | #14 | |
