07-16-2010, 07:18 AM | #1 |
| Glitching?
I have an AX10 with the 2s goat w/18.5 brushless, CC bec, Futaba 3pm 2.4 rx/tx, and 2s holmes lipo. When I am crawling it will jerk backwards at random quite frequently. The gear mesh is good, I cleaned out the rx, and bec with contact cleaner, and it still does it. Any suggestions would be extremely appreciated, thanks. |
07-16-2010, 07:29 AM | #2 |
Pebble Pounder Join Date: Dec 2009 Location: virginia beach
you have a capacitor on your esc?
07-16-2010, 07:33 AM | #3 |
07-16-2010, 07:36 AM | #4 |
is it leaking any fluid......
07-16-2010, 07:38 AM | #5 |
07-16-2010, 07:47 AM | #6 |
check your servo and receiver wires too make sure they arent running parallel to motor wires or battery wires
07-16-2010, 07:53 AM | #7 |
07-19-2010, 05:48 AM | #8 |
Power wires are ran seperate from everything else, put in a new rx, and it has gotten better but still ocassionally does it. WTF? |
07-20-2010, 01:30 PM | #9 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
07-22-2010, 11:06 AM | #10 |
Quarry Creeper Join Date: Jun 2008 Location: phx
Welcome to brushless. I've tried the novak and tekin and I always go back to brushed. For crawling, I just don't think brushless works as well as in other applications. My $.02
07-22-2010, 11:16 AM | #11 |
Rock Stacker Join Date: May 2010 Location: Anaconda
07-22-2010, 11:18 AM | #12 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
How is the sensor wire routed? They are very suseptable to damage, the slightest crack or extreme bend can wreak havoc on the operation. pop the harness off and go down the length looking for twisted, bent or broken wires. Ive been runnin a goat for @ 7 months now and have had no problems. Also make sure its been setup to your radio properly and the settings are correct as per the instructions.
07-22-2010, 11:33 AM | #13 | |
07-22-2010, 09:42 PM | #14 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
I've run the 2S Goat 18.5 all summer and had a similar thing happen. The antenna wire comming from the receiver I had rapped around a body mount to keep it out of the way. I straitend it out and ran it down a short tube that I can fold down under the body. Never had any problems again after that. How is your antenna wire ran? |
07-23-2010, 05:25 AM | #15 | |
08-31-2010, 07:23 PM | #16 |
I finally figured out where the glitch was coming from. I unhooked the Castle bec and no more glitching. I guess it got wet one to many times. |
