09-25-2010, 03:39 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
| MOA wiring question about motors?
Moa wiring question. Im wiring up 2 holmes prowounds to an XR10 with a punk dig. Which motor, front or back do I solder into slot 1 on the punk dig, slot 2 etc? And do I need to swap the pos/neg wires on the front or rear motor? |
09-26-2010, 12:36 AM | #2 |
It doesnt matter which motor goes where on the punk dig. You may have to reverse your aux channel to get the switch positions the way you want them and the LED for each dig position will be opposite but either way it doesnt matter. You will either have to reverse the wires on the motor or reverse the endbell (rotate 180) to get the rear motor to spin the oposite direction of the front. One thing to make sure of is that both motors have 0 deg or higher timing. |
09-26-2010, 05:27 AM | #3 |
Cool I found the endball was reversed so I just wired as needed. Thanks just wanted to check before all that soldering.
