10-15-2012, 07:44 AM | #1981 | |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
Overall I don't see the point of programming it. But that's why it's his video and not mine. | |
10-15-2012, 07:57 AM | #1982 | |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
10-15-2012, 08:23 AM | #1983 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help |
10-15-2012, 08:55 AM | #1984 |
10-15-2012, 10:55 AM | #1985 | |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
Another option is to replace the dial pot with a SPDT toggle with resistors. I also looked at using one of the thumb operated DTs to replace SW2 or the dial which would be my preference, but because the DTs are two buttons on PCBs it just complicates things. Maybe e-mails to Futaba from several owners could convince them to add this feature to a f/w upgrade? | |
10-15-2012, 12:26 PM | #1986 |
Newbie Join Date: Jan 2010 Location: Las Vegas
Sorry if this has been brought up but is anyone running LiPo in a 4pl? If so is a 2s 1550mah suitable?
10-15-2012, 12:47 PM | #1987 |
10-15-2012, 03:05 PM | #1988 | |
10-16-2012, 09:18 PM | #1990 | |
Quarry Creeper Join Date: Sep 2010 Location: Deus est mortuus, logica obtinet.
10-17-2012, 06:53 AM | #1991 |
Pebble Pounder Join Date: May 2009 Location: Northern Virginia, USA
| Re: Futaba 4PL Setup, Tips, Tricks & Help There's a ton of room. It might almost be possible to fit two.
10-17-2012, 10:54 AM | #1992 |
10-19-2012, 08:22 AM | #1993 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
Finally decided to splurge and get myself a 4PL. So far I love it! So many options and ways to tweak settings. Been following this thread for ideas.
11-18-2012, 09:11 PM | #1994 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Ok folks. I am now stumped, and could use a little help. I have a 4pl and am running a moa setup with dual mamba micro's. I have only my info lead going into my rx and my servo is running off my bec. Only one of my dual esc's is powering my RX. Tonight While trying to dial in my better laid out smash setup, I plugged everything in and my servo started freaking out. I pulled the non powered esc and started working with just my power source and my servo info lead. When I power up with ecs in channel 2 and my servo lead in power 1, I get this glitch. When I then power only the servo and plug the esc into the B channel it is smooth as butter. What am I doing wrong? Below is a pic of my smash. |
11-18-2012, 09:15 PM | #1995 | |
Powering everything through the RX is cleaner and easier and really keeps these issues from happening most the time. | |
11-18-2012, 09:36 PM | #1996 |
I actually have 2 recievers and tried it on both and the same things happened so your right. By wiring, I checked all the power wiring to and from my bec and it all looks good. I guess the power wiring could be weak around the esc thus causing a rough connection. Anyway I will get on it tomorrow. Thanks for the feadback.
11-18-2012, 09:46 PM | #1997 |
I would look at the ground more than anything else.
11-19-2012, 07:13 AM | #1998 |
Will do. I am not entirely sure I know what that means but what I do know is I will look at every black wire between the battery to esc to RX.
11-19-2012, 09:54 AM | #1999 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Some set-ups want a ground from the servo to the RX as well as the signal wire (you call it the "info wire".) So, BEC output red & black to the servo, servo black & signal to the RX (you will need to add another servo ground wire).
11-19-2012, 10:17 AM | #2000 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Agree with Charlie, I just finished wiring up my rig and I always run the black wire with the signal wire (something I got used to using Spektrum equipment. I just use a servo "Y" and take the red wire out of the RX end plug, that way you don't have to cut or damage the servo plug, ESC plug or BEC plug and are still able to make programing adjustments etc. much easier. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
