![]() | #2021 | |
20K Club ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| ![]() Quote:
![]() | #2022 |
Rock Crawler Join Date: Sep 2011 Location: truckee
![]() | #2023 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
![]() | #2024 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
![]() | #2025 |
Quarry Creeper ![]() Join Date: Apr 2009 Location: Ottawa, ON, Canada
I wrote a second 4PL mod thread, this time for a 3 position momentary switch! 4PL 3 Position Momentary Switch Mod Richard |
![]() | #2026 |
Pebble Pounder Join Date: Jul 2008 Location: Grand Island (middle of Nebraska)
Are they still updating the remotes still? Ive got one that needs updated.
![]() | #2027 |
Newbie Join Date: Feb 2013 Location: Uk
Hi, Not a crawler question but help would be much appreciated. With the 4PL Is there any way to set the dial control, a trim control (or even one of the switches to enable/Disable)to allow adjustment to a reduced speed mode like altering throttle EPA on the fly so I can quickly dial it down when my 5 year old wants a shot of my rc car? I have read this whole thread looking for something about this and hope there is a way of doing it. Regards Michael |
![]() | #2028 | |
| ![]() Quote:
![]() | #2029 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
| ![]() Cheap HobbyKing transmitter wheel. For under $10 I had to try it. Had other stuff in the basket and some weight leftover to add to it. ![]() So got it today and I am very satisfied with it. The parts fit correctly and they look sharp but more importantly the foam is softer than the stock Futaba wheel and to me it just feels better. For those that prefer the Futaba foam, it will slide right onto the wheel. All the parts were there. You get the small allen key, the wrenches are mine and they are all you need to swap the wheel. ![]() Not sure if that's normal but my kit came with two identical adapters, although they were labelled differently. Either one worked fine. ![]() ![]() Careful not to overtighten the five hex bolts that hold the wheel to the adapter, they are easy to strip. Took less than two minutes total. IMO it looks better and feels better. ![]() ![]() They also have them in different colors and styles. Sean ![]() |
![]() | #2030 |
Newbie Join Date: Feb 2013 Location: BONITA SPRINGS
can u help me with my 4pl..in my wraith the revesre messes up..the blue lite flashes n the motor goes with the flash..n breaks are weak..forward is fine..i got the vxl system hitec 7955 no bec..worked fine witrh stock radio...
![]() | #2031 |
| ![]() Calibrate the radio to the ESC. Check your esc manual for instructions.
![]() | #2032 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
Hey Harley great thread but i have a non crawler ? this is for a nitro boat how do you set up the 4pl to use the dt2 and dt4 buttons to operat a servo to use the buttons to ajust the servo as trim up and down to ajust the remote needle rich or lean.Hope this makes sence.Thnx Robert
![]() | #2033 |
RCC Addict Join Date: Mar 2011 Location: easton
great thread. i just picked up a 4pl yesterday to use on a wraith. after testing it im thinking about switching my go fast over to the same 4pl. anybody ever use the 4pl on a go fast? Sent from my iPod touch using Tapatalk |
![]() | #2034 | |
| ![]() Quote:
Sean ![]() | |
![]() | #2035 |
i dont race but i have an sc8e and sprint 2 besides the wraith and a clod. you answered my question though. Sent from my iPod touch using Tapatalk |
![]() | #2036 |
I use mine on my Durango sc truck and losi 22 works great.I also use it for my boats and have never had a glich or sig lose.
![]() | #2037 |
Just to add, other than the one that came with the radio, I don't use the R2104GF receivers. I buy the R204GF-E receivers. They are less expensive but more importantly for me it's because they have an internal antenna. If they have less range than the 2104GF (Futaba says 230 ft) I haven't noticed it either bashing or racing. The other difference that could be an issue on a crawler is that the 204 has a shared port for channel 4 and battery. The 2104 has four channel ports and a separate battery port. Sean ![]() |
![]() | #2038 | |
| ![]() Quote:
Futaba 4PL Setup, Tips, Tricks & Help The setting :100 is for 3 positions, just change for the number of positions or steps you want. | |
![]() | #2039 |
Thanx got it.
![]() | #2040 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
Ok , I bet this has been covered but heres my problem : I have a Xr10 with a punk dig , I hate sw2 for dig tho , Really easy to miss the middle of the switch . I would like either dt2 or dt4 to be dig . The main thing is they aren't switches , They're proportional and take for ever to activate dig . How can i make them front dig , Middle and back with 3 clicks ? Help please ![]() Hope it was clear enough , Jack . |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
