09-22-2013, 02:36 AM | #2081 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help
I recently picked up a 4PL, and it came with Model Memory 1 set up for a Special Op, which I assume to be an MOA. Channel 1 is steering, channel 3 is the 3 position switch, and channels 2 & 4 are throttle. I checked all the screens that I know of and all trims are set to 0 and all EPAs to 100%. Channel 2 is fine, no problem. Channel 4 seems to be overtraveling. If I use the DT4 slide, I can get it peeled back to where channel 4 stops at 100% fwd just like channel 2. However I can't get reverse on channel 4 to stop at 100%. Reverse on 4 seems to be about 118% or basically one column short of the outermost bar, whereas channel 2 stops at the 100% mark. Like I said, i haven't found a screen yet where the trims or EPAs were set all wonky, every screen I've found looks good. Anyone know what I may be overlooking? . |
09-23-2013, 10:47 AM | #2082 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
Check your programmable mix settings
09-23-2013, 03:59 PM | #2083 | |
Newbie Join Date: Sep 2013 Location: Sunnyvale
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
Did you ever get your issue resolved? | |
09-23-2013, 08:50 PM | #2084 | |
If you are not using the dual ESC programming than I suggest resetting the model and going from there. You should start with a fresh model on every new truck. | |
09-24-2013, 01:28 AM | #2085 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help |
10-12-2013, 07:19 PM | #2086 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
Just picked up a 4pls . Got it working for my xr and now looking to set it up on the wraith with a winch. How do I use the winch on this Tx? Like spool line out and spool line in. Or is it even possible on this Tx? Thanks for the help.
10-13-2013, 10:00 AM | #2087 | |
Or is your Wraith dual steer? (occupying channels 1 & 3) Or are you trying to set up a different switch (DT1-DT4) to control the winch? You're not trying to set up both the XR and the Wraith on the same model memory, are you? | |
10-13-2013, 11:45 AM | #2088 |
No duel steer and xr has owe receiver and owe model memory. I would like to have it on dt3 or dt4 don't matter just trying to figure it out. Thanks for the help. I will try and look at that sw2 stuff.
10-13-2013, 11:57 AM | #2089 | |
For the winch, I believe you want a "3 position switch" for whatever channel you're using for it. Duel = "fighting" Dual = "two" | |
10-13-2013, 12:23 PM | #2090 | |
I set up my DT3 to control channel 4 and got it working, but the DT switch acted just like a trim in that I had to hold it in one direction and let it build up. Unless I'm doing it wrong, I think with a winch it'd be kind of a pain to sit there and hold the DT until the winch got going fast enough. Then you'd have to hold it in the other direction to get the thing to stop. The SW2 might not be in a convenient spot, but at least it's a full on-off-on, so your winch runs at full speed soon as it's called into duty. If anybody's figured out how to use the DTs as on-off-on, please post up. I'd like to learn about that, too. | |
10-13-2013, 12:47 PM | #2091 |
I also must be doing something wrong. I can't get the sw2 switch to work the winch. It says it working on screen but no power to winch or any noise.
10-13-2013, 01:02 PM | #2092 | ||
Stock I believe it's a "trim switch", thus the need to hold it. As a 3 position switch, it should do "100 - 0 - -100" Do you have the (2 year old??) crawler update?? | ||
10-13-2013, 01:32 PM | #2093 |
On the LCD screen when I use the sw2 button it goes to 100 then I put in center it goes 0. I think that I have new update with the pls but I could be wrong. How do I setup a 3 position switch? I have seen a mod that you have to solder in a few things. Is that the one you thinking about.
10-13-2013, 02:54 PM | #2094 |
I got it to work on the sw2 button. Now the problem is the winch motor is always running even in neutral. Thanks for all the help.
10-13-2013, 04:11 PM | #2095 | |
10-13-2013, 05:05 PM | #2096 |
10-13-2013, 06:21 PM | #2097 |
D666.... early in this thread they tell you how to determine if you have the update or not. As to the "3 position switch", that is for a simpler radio that needs a mod. The 4PL is just a setting in the TX software. I don't have my sons 4PL in front of me, thus can't help. Trubble, same thing, early in this thread is info on seeing if you have the update. For both of you, the update should not hinder getting a 3 position switch set, it's more for dual ESC mixing, etc. |
10-13-2013, 06:28 PM | #2098 |
RCC Addict Join Date: Oct 2012 Location: Norcal
I use my 4pl on three different rigs. On my Ridgecrest I use DT4 for the dig. On my scale SCX10 I use DT3 for the two speed tranny and DT4 for the winch. I got this all set up by using Harley's help in the beginning of this thread. Futaba 4PL Setup, Tips, Tricks & Help Last edited by Norton; 10-13-2013 at 06:31 PM. |
10-17-2013, 10:11 AM | #2099 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
To setup a DT switch for 3 positions set the Step amount on the TRIM.DIAL screen to 100. See pages 60 and 61 in the manual. Now be warned, this will not be momentary: from neutral you push the DT switch to start the winch in one direction, then pull the DT to come back to neutral and stop the winch. Do the opposite for the other direction. If you want momentary action you need to physically modify the radio as per my thread since the software doesn't support it. 4PL 3 Position Momentary Switch Mod If your winch drifts when in neutral you can adjust the trim in the CH3 CH4 menu. |
10-18-2013, 01:33 AM | #2100 |
Newbie Join Date: Jan 2013 Location: Australia
Hi What is the 4PL "dig switch glitch" mentioned early in this thread ? I did a search and didn't get anywhere, having a small blip of power to the rear motor when on front dig,thought it might be the ESC but now thinking it might be a transmitter issue. Thanks Dave |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
