Thread: Futaba 4PL Setup, Tips, Tricks & Help
Old 03-01-2014, 11:59 AM   #2141
Default Re: Futaba 4PL Setup, Tips, Tricks & Help
For those who have asked "will the blah blah blah rx work with my 4PLS?"
lostonthetrails is offline   Reply With Quote
Old 03-06-2014, 04:18 PM   #2142
Sold my 4pl today and bought the 4pls. I can't get my bold rx's to bind to my new radio and I can't get my dig to work. :( someone help.
jeremyfowler33 is offline   Reply With Quote
Old 03-07-2014, 06:23 AM   #2143
I just bought a 4PLS, can anyone tell me which charger I need to get if I want to use NiMH batteries? The manual isn't very clear on this.
Jeff@TireBalls is offline   Reply With Quote
Old 03-16-2014, 08:19 PM   #2144
I want to buy a 2nd 4PL for my son. My question is, can I program 2 radios to drive the same car.
I want to share my rc car collection with my son and be able to drive with him. Not sure how Futaba handles that.
MaxxPain is offline   Reply With Quote
Old 03-16-2014, 08:34 PM   #2145
You will need to rebind the receiver to go from one radio to the other, but it doesn't need to be linked to a specific model on the radio.
Stregone is offline   Reply With Quote
Old 03-16-2014, 10:31 PM   #2146
Are you saying each time I use the car I would need to rebind it.
Old 03-17-2014, 08:30 AM   #2147
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Only if you are switching radios. The RX is bound to whatever radio you last used it with. You wouldn't want your son to turn on his TX while you were driving and suddenly send it off in the wrong direction.
Harley is offline   Reply With Quote
Old 03-17-2014, 10:28 AM   #2148
what about setting one RX to different models for the same rig but different settings, for instance:
model #1: my settings
model #2: my son's settings
pmadrid13 is offline   Reply With Quote
Old 03-17-2014, 10:35 AM   #2149
20K Club
Harley's Avatar
Yup, the radio will do that just fine. That is one big difference between a Futaba and something like a Spektrum.
Old 03-17-2014, 02:11 PM   #2150
Thank you Harley, I been running Spektrums for a while and will be converting over to Futaba. This should cut back on some of the damage my son has cause on some of my rigs.
Old 03-17-2014, 03:30 PM   #2151
Thats a great idea..
Old 03-19-2014, 09:40 AM   #2152
I searched the thread but couldn't find the answer. Can someone help me setup my radio for lights? I have the heyok dual light 3 position controller to operate the stock Wraith lights and a VP MORE light bar. I can get the lights to turn on with the DT1 switch but they are very dim. What am I missing?
Old 03-19-2014, 11:04 AM   #2153
20K Club
Harley's Avatar
The MORE light needs to be run on a 3s power source (12v), the RX is probably only supplying it with 7.4 at the max.
Old 03-19-2014, 11:11 AM   #2154
I tried it with another stock VP bar that I have and it's the same thing, they are so dim that you can hardley tell their on.
Old 03-19-2014, 11:12 AM   #2155
20K Club
Harley's Avatar
VP light bars are also designed to run on 12v.
Old 03-19-2014, 11:14 AM   #2156
But they will run on 7.4 and still be pretty bright according to the MORE thread. Something else is going on.
Old 03-19-2014, 11:15 AM   #2157
Can you do a wright up on how to proberly setup this controller on DT1?
Old 03-19-2014, 11:16 AM   #2158
20K Club
Harley's Avatar
Sounds like you have a voltage issue. I would check the output of the Heyok and see what voltage it has.
Old 03-19-2014, 11:17 AM   #2159
20K Club
Harley's Avatar
I don't have one of the controllers. I'd have to look into the setup. Should be a standard 3 position setup like I have link on the first page.
Old 04-01-2014, 02:00 AM   #2160
Proverbial threadkiller
Trubble's Avatar
Question Re: Futaba 4PL Setup, Tips, Tricks & Help
Ummmmmm,
let's say there was 'this guy'......
and he did some mod on his 4PL to gain more forward travel on the throttle trigger......
and since this is a completely hypothetical scenario,......
let's say he went through the adjuster procedure (p 97? in the manual).....
and just for giggles, let's say it was a success........
Now, are the new endpoints learned, in ALL model memories?
Or just model memory #3, and the Adjuster process has to be repeated in each and every profile?
Trubble is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html
Posted By For Type Date
Futaba 4PL - Modelbouwforum.nl This thread Refback 11-08-2011 05:06 AM
Scaler Radio Help - Radios & Servos @ URC Forums This thread Refback 11-02-2011 02:46 PM
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL This thread Refback 10-27-2011 03:41 PM
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby This thread Refback 10-24-2011 03:51 AM
Futaba T4PL - Elektronik - rockcrawler.de This thread Refback 10-11-2011 04:01 AM
4PL Dual ESC - YouTube This thread Refback 10-09-2011 08:27 AM
ZONACRAWLING • Ver Tema - emisora 4pl This thread Refback 10-05-2011 04:42 PM
