05-26-2014, 04:44 PM | #2181 | |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
12-31-2014, 05:48 PM | #2182 | |
Quarry Creeper Join Date: Sep 2014 Location: pacific northwest
Its a RC4WD winch | |
12-31-2014, 06:55 PM | #2183 |
RCC Addict Join Date: Oct 2012 Location: Norcal
I use the two DT switches on the pistol grip, one for winch and one for 2nd gear. Wireless sucks, not a lot of range and another thing to fiddle with. |
07-17-2015, 07:30 PM | #2184 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
I had a 4pl for years and setup my 2.2p a loooong time ago. I no longer remember how to do it. The 4pl finally bit the dust, so now I have a 4pls. Will the dual esc setup be the same on the pls???
07-18-2015, 06:49 AM | #2185 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Yes its pretty much the same except for the dig function. For your dig switch on the "DT" buttons you will need to program for "ESC-MD/*3P" and ESC-RT for rear motor trim, which I think is the same on the 4PL. PM me if you have any questions.
07-18-2015, 12:04 PM | #2186 |
As Brit said, pretty much the same. We just went through the programming with her actually. Hadn't had to do that in awhile! |
07-18-2015, 06:05 PM | #2187 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Thanks, I've been doing rc crawling for a long time now and this is still my least favorite thing to do and I can never seem to get it right. It would be great if you did a video update and show doing a dual esc setup with the 4pls. |
07-20-2015, 08:43 AM | #2188 |
Newbie Join Date: Apr 2015 Location: Lawrenceburg
Thanks for all the great info
10-22-2015, 03:37 PM | #2189 |
Rock Stacker Join Date: Oct 2015 Location: flagstaff
thanks for the awesome thread Harley, i had to dig around a bit to follow the differences from the 4pl to 4pls but it was super easy. keep up the good work dude!
11-21-2015, 03:43 PM | #2190 |
Pebble Pounder Join Date: Oct 2007 Location: in a van down by the river
Need some help i bought a used 4pl looking to return to default settings. Looked in manuel pdf but did noy see
11-21-2015, 04:14 PM | #2191 |
There is no master reset, go to page 41 in the manual. That's as close as your going to get. Seems pretty stupid that there wouldn't have a master reset. I'm running the 4pls now and it has one. Last edited by Norton; 11-21-2015 at 04:21 PM. |
11-22-2015, 02:30 PM | #2192 |
Quarry Creeper Join Date: Jun 2009 Location: Abbotsford BC Canada
Which is better for a 4ws set up.The 4pls or the 3pmx?..i was also wondering if end point adjustments on rear steer can be done independentely of front steer?..Hope my question is clear..Thanks for your time
12-02-2015, 09:15 PM | #2193 |
Newbie Join Date: Jan 2014 Location: Darwin
Just finished building my crawler, having issues with channel 2 not reversing. I have managed to set up the dual esc settings and digs. Channel 4 has both forward and reverse but channel 2 only forward. Is this normal? Also, my motors are not sync'd, rear lags in start up and turns. I have two Holmes BR mini's Any info would be appreciated it is my first moa crawler. |
06-29-2016, 02:42 PM | #2194 | |
Rock Stacker Join Date: Jun 2016 Location: USA
I have setup ESC-RT and ESC-MD/ 3P i can drive foward and backward but i don't have Dig. i can only go back and forward on 4wd set and rear drive with front dig but no dig, and if i dig rear and front driving i have no throttle at all. Last edited by skyraiD; 06-30-2016 at 11:25 PM. | |
09-07-2016, 06:13 PM | #2195 |
Newbie Join Date: Jan 2011 Location: PORTUGAL
sorry to dig this up again... can a used 2th hand futaba 4pl still be updated by futaba ? any ideas of the cost to it ? thanks to anyone with some help !! |
09-07-2016, 11:55 PM | #2196 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Only a small number needed to be updated. You are sure yours is one of them? Otherwise, it's most likely just the shipping charges that you'll be looking at.
09-11-2016, 07:05 PM | #2197 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
4PLS with a R204GFE receiver in either one of my rigs. Everything works fine on one truck but I switch to another and only steering works. I can switch to ANY other model in the transmitter where it says "NO LINK" and steering still works but no throttle. I've tried to calibrate the ESC to the RX numerous times and it recognizes neutral but not forward or reverse. WTF is going on?? This setup worked fine when I first got it but shit went wrong real quick when I binded my crawler to the transmitter. Really wishing I stuck with Spektrum right now |
10-30-2016, 07:02 AM | #2198 |
Read far too many pages on the 4PL here, I have a 4PLS and biggest issue in setup is setting throttle subtrim....IF its not correct, NOTHING WORKS.....but the display does. How about an updated thread for the 4PLS ?? |
10-30-2016, 12:41 PM | #2199 |
I can't seem to get to page 111 on this thread.... last post is showing up on page 110, but I see an indicator for page 111 and can't move to it by clicking on the 111 or the forward arrow - strange....
10-30-2016, 01:10 PM | #2200 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
I pulled an old dual-esc XR10 out of mothballs and followed your Dual Esc video for set-up. Perfect. But the main page shows no indication of Dig or Bias status (other than watching bar-graphs). Do I need to drive with the Dual Esc Setup page showing to get indicators, or is there a better way?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
