04-05-2011, 10:49 AM | #941 |
Rock Crawler Join Date: Sep 2005 Location: IDK
So can't do front AND rear digs with mine?
04-05-2011, 10:53 AM | #942 |
04-05-2011, 11:01 AM | #943 |
TEAM RCC Join Date: Oct 2005 Location: THE ALIEN WORKSHOP
Thanks for the great thread Harley Lots of good info made programing painless |
04-05-2011, 11:02 AM | #944 |
04-05-2011, 11:02 AM | #945 |
Oooh allright, so one push for an example will be front dig, then push it again and it's in rear dig and when pushed again it will be out of dig i presume? Thanks for the quick response! |
04-05-2011, 11:03 AM | #946 |
04-05-2011, 12:14 PM | #947 | |
| Quote: Is says it's not available | |
04-05-2011, 12:20 PM | #948 | |
To program your radio you need to assign the button on the grip to the dual esc function. The DT programming for biasing is the same as the current video. | |
04-05-2011, 12:25 PM | #949 |
I think i will get used to the push button setup, i will email RobbeFutaba nevertheless. Thanks for this thread Harley, quite helpfull to say the least |
04-05-2011, 01:31 PM | #950 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Hey Harley, What rx do you reccomend I run in my crawlers? Just the same one it comes with, or is there a better option? It seems I saw there is a HV rx available??? Thanks |
04-05-2011, 01:33 PM | #951 |
| I'd just pick up more of the same model that it comes with. It is cheap, 4 channel and capable of running HV (rated to 7.4).
04-05-2011, 01:54 PM | #952 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
I may have missed it, but can anyone recommend a good carrying case for the 4PL? Mine should be here tomorrow and definitely want to protect it! |
04-05-2011, 02:01 PM | #953 |
04-05-2011, 02:02 PM | #954 |
Good deal. Thanks, Harley! |
04-05-2011, 04:20 PM | #955 | |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
04-07-2011, 02:40 AM | #956 |
I got my raduo set-up, it's a non-update radio thoUgh. Mine is setup like so: Top DT1 button is for t bias the rear axle, BUT i did this so it does it in 100% increments. This way i can shut the rear of more easy as it is the most used function. I do have another bias on the DT2 to use the bias with 20%increments. The grip button seems so uncomfortable and slow when cycling trough the front-rear-4wd modes. I will try this setup first but it's very likely that I will do the update as this is pretty complicated still. |
04-07-2011, 10:46 AM | #957 |
Rock Crawler Join Date: Mar 2009 Location: houston
just wanted to give a to futaba!I sent my 4pl to them for the update and the turnaround was one week with shipping!Btw I like it alot more with the update.
04-07-2011, 04:16 PM | #958 |
Quarry Creeper Join Date: Aug 2009 Location: Snohomish, WA
I just got my 4PL in and I have a question or two... 1. If I am not running dual ESC's - do I need to update for any reason? 2. Can I program this current SW for independent control of rear steer? Thanks, Mike |
04-07-2011, 04:23 PM | #959 |
| The update only effects dual ESC setup. What do you mean about programming the SW for independent rear steer?
04-07-2011, 04:29 PM | #960 | |
I assigned CH3(where I will put my rear servo) to DT3 and DT4 w/ 30 increments but it does not show on the screen when I test it... | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
