04-11-2011, 09:34 PM | #1001 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
RX |
04-11-2011, 09:43 PM | #1002 |
Pebble Pounder Join Date: Feb 2011 Location: Gawga!
Moved to channel 4. Same thing. I just don't understand. It has to be something I turned on or something cause it acts just like you are hitting the brakes when you go from forward to reverse. Everything works as it should now but with no reverse. Can I do a master/default reset to the tx and start over again without having to create a new model number? thanks again guys.
04-11-2011, 09:53 PM | #1003 |
04-11-2011, 09:58 PM | #1004 |
04-12-2011, 07:39 AM | #1005 |
| If it acts like you are hitting the brakes then the TX is doing it's job unless its just the drag brakes. You can do a model reset and it will clear that model. I would just select a new model and test out the ESC as I think the problem is not the TX.
04-12-2011, 10:55 AM | #1006 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
I'm thinking the problem is still in the punk? Esc is showing the red light while reversing like intended. I've swapped the punk and switch over to the fourth channel and didn't change. The display on the Tx is showing forward and reverse on graph. I'll post up what I find tonight. For a quick test I'll remove the punk and use that same Esc on one of the motors to see what happens It was working great before Jerry. Stop messing with it! JK Edit: Okay...Had time before lunch to mess with this thing. Removed the punk dig completely. Took one of the motors and wired to Esc. Still no reverse. I'm thinking the settings in the micro might have gotten changed? Once I get home I'll hook it up to the castle link and see.. Last edited by Sneed; 04-12-2011 at 11:40 AM. Reason: Added info |
04-12-2011, 12:55 PM | #1007 | |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
This is one feature missing in this radio, they didn't provide the 'alternate' or momentary mode for switches other than SW1. But it's still a great radio and I love it My solution will be to replace SW2 with a momentary toggle but only once the warranty is over Another idea I've been thinking of doing on my Bruiser is to use a 2 position switch to control a relay that will switch the ESC output from the truck's motor to the winch motor. This way I'll control the winch with my throttle and the relay would short the truck's motor for brakes in winch mode. This does require that both motors be brushed, and I won't be able to drive and winch at the same time. | |
04-13-2011, 11:30 AM | #1008 |
Sneed got my xr and 4pl workimg as 1 again. Somehow I managed to change the settings in the mamba micro to no reverse without a castle link at that. Just wanted to let you know what had happened. Thanks again Harley and everyone else that tried to help me out.
04-13-2011, 11:33 AM | #1009 | |
04-13-2011, 11:41 AM | #1010 |
04-13-2011, 11:44 AM | #1011 |
04-17-2011, 07:33 PM | #1012 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
ok so i just tried to rea through this whole thread, i got about half way and gave up. so im trying to figure out if i should get a 4pl or go all out and get a 4pks. I have a lcc and im eventually going to get a scaler, and a moa comp crawler. i tried a guys 4pk with an xr10 today and really liked how it felt and operated. i liked how you could push the button on the grip for front dig, and a buton near the wheel for rear dig. Can a 4pl do this/ can it have 2 diff butons for front and rear dig? if not can someone show me a link or make a vid that shows how to do a dig. im trying to get the best radio that i need. i also race short course trucks so i will need to use it for that also.( iv been using a traxxas 2.4 2ch radio so any thing would be an upgrade) thanks for helping and sorry for the long post |
04-18-2011, 04:41 PM | #1013 |
also with ^ is it pretty easy to set up a moa on it/ and a lcc on it?
04-19-2011, 08:01 AM | #1014 |
I went to The Source and found a barrel plug that fits the charge jack. It's a Nexxtech 2741571A, 1/8"(3.5mm) OD, 1/16"(1.3mm) ID. Once I got it wired up I realized that the TX has a diode behind the charge jack so I can't use a peak charger. I just put the plug on my very old RX pack trickle charger since I currently use a 4 cell NiCd pack. |
04-19-2011, 06:58 PM | #1015 |
Quarry Creeper Join Date: Oct 2008 Location: A little town called Dallas
Harley, I just wanted to say thanks for this thread I just got a 4PL and this has helped me get it running correctly the very first try. Runing 2 Mamba Micros in my new Berg and the 4PL works great |
04-21-2011, 09:30 AM | #1016 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Harley! YOURE MY HERO.....This is the second thread and second Futaba controller for me becuase of your write ups! I love my 4PL and my 6EX because of you. If I were gay I would kiss you on the lips (open mouth).... |
04-21-2011, 10:08 AM | #1017 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
04-21-2011, 11:02 AM | #1018 | |
Glad to help brother | |
04-21-2011, 11:03 AM | #1019 |
04-21-2011, 11:48 AM | #1020 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
For those who missed it like I did, Neal now has 4PL skins! http://www.freqeskinz.com/index.php?...d=22&Itemid=64 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
