![]() | #1041 |
20K Club ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
4PK case works great and is great quality. If you want something a little cheaper just about anything made for a 3R works well too.
![]() | #1042 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
Too long to read, sorry if this was asked before Is there a way to set it so on the main screen you can see a percentage of the mixing? |
![]() | #1043 |
![]() | #1044 | |
RCC Addict Join Date: Sep 2006 Location: Depew
| ![]() Quote:
Menu -> Advanced -> Dual ESC Then just drive from that menu. It shows you if you're in dig and what percentage the ESC's are at. That's how I drive with mine. | |
![]() | #1045 | |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
| ![]() Quote:
![]() | #1046 |
I'd like to thank Harley for working with futaba to get this radio released and updated. It's perfect for most crawlers, and the price is perfect ![]() I setup the wifes new rig & 4pl yesterday and had only one issue. The throttle ch and ch4 need to be reversed before calibrating ESC, or the motors will spin backwards in relation to throttle. Didn't know what I was doing wrong so I did a search of this thread and found mrdrinksalil had posted up with the same issue. Reversed the two channels and recalibrated, and presto! Perfecto! You should add the channel reverse instruction to the first post Harley The 4PL is no 4PKS, but it definitely Rocks! ![]() |
![]() | #1047 |
Pebble Pounder Join Date: Aug 2006 Location: Raleigh NC
So I bit the bullet and picked up a 4pl from my LHS the other day, 239 OTD, which I thought was an good price. I'm running it on my shafty with Dig, so a few questions here. I want to setup where I can have 4wd, freewheel and locked for the dig servo. I've read through the manual a couple of times and have tried some "solutions" but nothing has worked to this point. Can you give a walkthrough Harley? Thanks BTW, so far I love this radio, aside from the dig servo, everything has been easy to set up/use. Now I just need to pick up a XR10 and use this radio to its full potential ![]() |
![]() | #1048 | |
| ![]() Quote:
![]() Go to the Dial/SW menu. Select Trim.Dial Select which DT switch you want to control your dig. Set the values to the following: DT(#):CH3 (or CH4) :100 :NOR Last edited by Harley; 04-26-2011 at 11:25 AM. | |
![]() | #1049 |
hey man no worries, that seems like an easy setup that I could even follow ![]() I appreciate the help/time that you have taken with this thread ![]() |
![]() | #1050 |
![]() | #1051 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Holy hell...information overload by page 36. My main question is: If I'm going to run rear steer on a scaler, is there a thumbwheel like the 4pk to roll from side to side? Also, can you set it up to auto center with the push of a button? Thanks, Tim. |
![]() | #1052 | |
| ![]() Quote:
There is no auto center feature unless you are running the built in 4WS option. Have you taken a look at that video? It is linked in the first post. | |
![]() | #1053 |
Hey Harley, Just got my dig programmed per your instructions, holy crap was that easy. Dig functions perfect now ![]() 4pl worked great ![]() Thanks again for the easy instructions. Zack |
![]() | #1054 |
![]() | #1055 |
Thanks for the response Josh. Not planning on using the 4ws option right now....I like to have independent control. In fact after reading this thread, I ordered a 4pl from Tower last night and 2 extra receivers from RPP (tower was out). Should be here next week. Thanks again. Tim. |
![]() | #1056 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
just got my 4pl yesterday and set it up today. It was really easy to program the dig thanks to harley. I used DT4 for my dig on my lcc. Thanks for the help ![]() and for those thinking of geting one, GET IT! its as amazing as you think it is ![]() |
![]() | #1057 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
Ok, scaler application.....Running 4WS on channels 1 and 3. Works well...My winch is on channel 4 activated on DT2 at 100% forward and reverse with a pause in the middle. Still good. The problem is when I run my winch, it also moves the rear steer on channel 3....I searched the menu 4 times with no luck as to why this happens...Any ideas on what is wrong with my setup?
![]() | #1058 | |
| ![]() Quote:
![]() | #1059 |
![]() | #1060 |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
