06-24-2011, 12:00 PM | #1221 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Harley is there a really noticeable difference in recivers? Just wondering if it's worth swapping recivers. Thanks.
06-24-2011, 12:24 PM | #1222 |
06-24-2011, 02:39 PM | #1223 |
06-25-2011, 01:29 AM | #1224 |
Pebble Pounder Join Date: Jan 2010 Location: YYZ
Are all currently shipping 4PL updated to latest firmware? Local shop told me that they can order from their distributor. (i am from Canada) Ooops, one more thing... Is there any label on the box itself that will tell this info ? Last edited by xxgg; 06-25-2011 at 02:09 AM. |
06-25-2011, 01:48 AM | #1225 |
06-26-2011, 08:12 PM | #1226 |
Thanks Harley for all your help on this thread and info. Thanks.
06-30-2011, 02:11 PM | #1227 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
is there any special set up you have to do when you first turn it on? im getting nothing from my motor... might be esc as well but figured i would post here as well seeing they are both new.
06-30-2011, 02:13 PM | #1228 |
| You really haven't given me any info. Is the RX bound? What color is the LED? Do you have steering? Does the ESC have power? Did you turn the switch on the TX to the power on side (not display only)?
06-30-2011, 02:17 PM | #1229 |
whoops my bad.... knew i forgot something. esc gets power, green led flashes, when hit throttle light goes solid red. steering works and lights come on.
06-30-2011, 02:25 PM | #1230 |
The ESC is seeing signal from the radio then. So the radio is fine. What's the ESC?
06-30-2011, 02:27 PM | #1231 |
brxl... I have a post going in the HH thread for that with JRH rite now seeing what if anything is wrong on that end. just figured i would check in here for the 4pl side of it
06-30-2011, 02:29 PM | #1232 |
Did you calibrate the ESC first? Should always be the first thing you do with any ESC in any car.
06-30-2011, 02:40 PM | #1233 |
DANGIT!!!! You got me... Im an idiot!!! thats what happens when you get up at 4 for work!!! works great now!!! lol <-------- |
06-30-2011, 02:41 PM | #1234 |
Easy fix. Glad to help.
07-05-2011, 08:55 PM | #1235 |
Newbie Join Date: Apr 2010 Location: reno
Is it possible to make the 4pl show you how much mix you have engaged? Like on the 4pk when you mix there is a number that changes, is there a way to have something like that on the main screen because i dont like having to stop in a comp and pull the trigger while watching the graphs to see how much i have engaged, thanks Nick
07-05-2011, 09:01 PM | #1236 |
No, that is one difference between the 4PL and 4PK. After awhile you probably won't need to look, you can do it 95% off feel.
07-05-2011, 09:05 PM | #1237 |
ok thanks so far I am really loving the 4pl but my dad has a 4pk and I noticed those numbers on there. Thanks anyways I was just wondering if that was possible, Nick
07-05-2011, 09:05 PM | #1238 |
looking to upgrade to a lipo any suggestions in size, or should I stay with the 4 AA?
07-05-2011, 09:06 PM | #1239 |
07-05-2011, 09:15 PM | #1240 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
