08-12-2011, 02:06 PM | #1381 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Yes both ESC's calibrated. When first hooked up my motors ran backwards. Reversing on Throttle-1 page only fixed the front motor. I had to also reverse CH4. That's what lead me to believe I had to adjust expo on both channels separately. But I don't see a way to do that.
08-12-2011, 02:10 PM | #1382 | |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Seems KISS is true as always. | |
08-12-2011, 02:17 PM | #1383 |
08-12-2011, 02:48 PM | #1384 |
Some thinking about my aircraft radio switches while flying. The 4PL SW2 could be positioned between DL1 and antenna (next to it) but in the form of three position toggle switch. Easy to get to with index finger and if the correct switch is used, (3 position typical from JR) the clicks would be quite positve. Unlike the feel of SW2 on the 4PL. The feel of SW2 I think could be improved quite a lot as it's difficult to operate with either thumb and does not give a positive feel. |
08-12-2011, 02:51 PM | #1385 | |
The design of it is recessed so that it is not hit by accident. While not as ideal for us in some circumstances it does it's job. The more drive time you get the more you get used to it. | |
08-12-2011, 03:11 PM | #1386 | |
While prorgamming 2ESC, I did the same with SW2 as what I could do with DT4. Front and rear dig. With the body post mod to SW2 it would be possible to opperate SW2 with either thumbs. SW2 just might find allure to some drivers if they could change it to short reach 3 pos toggle switch. Steering thumb would be wost usefull then for flicking the switch. | |
08-15-2011, 10:15 AM | #1387 |
Just got my XR10/4PL/dual Crawlmasters/FXR's running this weekend. Followed Post#1 diagram. Works but bottom end is not smooth and minimum speed is too fast. When I went to dial in negative expo, I set it at -50 on "thottle-2" page but it appears to only have affected the front motor. When I look over at CH4 menu, I don't see an expo option for the rear motor. ESC's are calibrated, but I haven't been able to get Hotwire working yet, so can only set up button-pushes. |
08-15-2011, 10:19 AM | #1388 | |
08-15-2011, 10:29 PM | #1389 |
| Hallo Harley, In the above picture you show the BEC(CC 10A BEC) going itno the RX. Would this be ok if the Steering servo (Savox SA-1283SG) draws high current? How would one have to wire the BEC to get it otherwise and how should I wire it if the servo is running at 8.5V (HD DS8325HV servo)? I'm asking this due to the grounding of all the black wires into the RX and if the servo is running of the BEC. Kind regards Rudolf |
08-15-2011, 10:39 PM | #1390 | |
Basically you need to send the red and black from the BEC To the servo , then send the yellow (or white) from the servo to the RX. You will need to leave the red wire from at least one ESC plugged into the RX. | |
08-15-2011, 11:00 PM | #1391 |
Both servos gives about 31kg.cm torque at 6V but the HD can go to 8.5V, thus the HV abreviation at the end. I'm just curious on how the Futaba system will react to the servo not being grounded into the RX. I just had loads of problems with this type of setup on another brands system and dont want to hurt the new Futaba. |
08-15-2011, 11:13 PM | #1392 |
It's hard to say how it will react. Many servos act differently and it's not all based on the radio system.
08-15-2011, 11:36 PM | #1393 |
Thanks, Will post results when I'm done with it. |
08-16-2011, 09:09 AM | #1394 |
Rock Stacker Join Date: Jan 2010 Location: Elko
| Battery pack question
The cute strawberry blonde UPS lady visited me this morning with my new 4PL, I've been seeing postings about using lipo battery packs which brings up some questions are they worth it and can someone recommend a few good ones Thanks guys |
08-16-2011, 09:19 AM | #1395 |
| DO NOT USE LIPO. You can use LiFE packs though. It was talked about in this thread a bit. Search for 4PK LiFE pack when shopping.
08-16-2011, 09:20 AM | #1396 |
08-16-2011, 02:20 PM | #1397 |
08-17-2011, 01:00 PM | #1398 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Multible Models
I need help with multible models. I have 3 trucks and noticed all 3 models have the same trim settings, steering, Throttle, 3rd Channel, like a Global settings for all models. In fact, I noticed if I turn on my radio and have it on the wrong model, I can drive the car. Do you know of a setting to change this so all models dont share setting nor the same channel. I have the same RX for all my trucks as the RX that came with the radio. Thanks Brad |
08-17-2011, 01:12 PM | #1399 | |
Futaba RX's are bound to the RX not to an individual model. So no matter what model you have it set to the truck will still react to the radio. | |
08-17-2011, 01:16 PM | #1400 |
Pebble Pounder Join Date: Jul 2008 Location: Tamworth, England.
I have 5 or 6 different model`s assigned to my 4Pl, and I have no issues with the different models settings. Just a quick simple question, have you have got them assigned to different memory locations?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
