06-14-2012, 03:01 PM | #1921 | |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
I hope they know too, I'd hate to lose this gig! | |
06-14-2012, 06:04 PM | #1922 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Tommy, one of the things I do with my PL is turn all the external switches of that I am not useing,including the trim buttons. No chance of hitting a button and screwing up a trim that way. All of the trim functions can still be acessed thru the menu if needed. Basically my winches and 4 wheel steer are the only active switches on the scale rigs. On the comp rigs I have the bias and dig functions active. |
06-14-2012, 07:51 PM | #1923 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
That's what I do, too, Devlin. That's why I'm not really sure how this setting got tweaked. But it's all good now. |
06-16-2012, 02:23 PM | #1924 |
Pebble Pounder Join Date: Jan 2009 Location: Olympia
Hello guys, I re-wired my rear motor so it's wired backwards and now the mixinig is perfect but I have one problem, when I try to lock up the front it's still in 4wd? Can any one help me out? I was trying so many things that I messed something else up! Thanks in advance! Everything else is perfect. Love the 4pl for crawling! I just noticed the FXR's are taking about 30seconds to function and sound the startup tones. Last edited by Jstall7543; 06-16-2012 at 03:20 PM. |
06-16-2012, 04:43 PM | #1925 | |
06-16-2012, 07:21 PM | #1926 |
Ive tried every thing and the radio keeps applying throttle to channel 2 even when the dig is in the rear position. I wish I could do a reset on this I'm not sure what I messed up. I recalibrated each fxr sepperatly, I have perfect mixing and rear dig just no front dig. I did work as it should prior to reversing the rear motor wires. This is in a xr10 by the way.
06-16-2012, 07:46 PM | #1927 | |
You can go to the model and do a model reset if you want to start over. | |
06-17-2012, 02:11 AM | #1928 |
Cool! I thought I was doing a re-set but I had to look over the instructions closer! Thanks for your quick responses Harley! You are the Master! Now I just hope it's not raining tomorrow so I can play!
06-26-2012, 12:00 PM | #1929 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
Hi everyone, I recently bought Futaba 4pl radio and i want to ask you in which position of the receiver,i must plug the wires of Novak m2 dig and what can i do to setup the dig to work car? Thank you in advance. |
06-26-2012, 12:04 PM | #1930 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help This has been covered many time a but I'll reinforce it again. DITCH THE M2. The Futaba will do what the M2 is trying to do. It is a very unreliable and troublesome ESC. I really can't help you much with the setup, none seem to work the same or work correctly. I would suggest the M2 thread for more specific info. I will help you program whatever buttons you need but for more specific setup info I can't help you.
06-26-2012, 02:50 PM | #1931 |
I am sorry if it has been said but I asked again because i am hurry. I will do my question on a topic about m2 dig. Do you believe that m2 dig is useless? I ask you because i bought it new 130$. Thank you. |
06-26-2012, 02:51 PM | #1932 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help |
06-26-2012, 03:12 PM | #1933 |
06-26-2012, 03:33 PM | #1934 |
06-26-2012, 04:22 PM | #1935 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help +1. I had one that was part of a used XR-10 I bought. I tried a number of things but was never happy with: -Lack of drag brake -Proportional wasn't great -Couldn't use the programming cable -Everytime you recalibrated the ESC to the RX, all the other ESC settings went back to factory default, meaning I had to count button pushes and LED flashes....yet again.... I sold it to a club member since he had one and wanted a working spare. I replaced it with 2 new CC Sidewinder micros. Now the rig & I are happy. |
06-27-2012, 12:34 AM | #1936 |
I understand, but now I do not have enough money for something else. Sure I have two new Tekin-fxr but rather put them in another project. Thank you. |
06-27-2012, 08:40 AM | #1937 |
07-05-2012, 05:01 AM | #1938 |
Quarry Creeper Join Date: Jan 2010 Location: Clover
hi All, I'm encountering an issue on my Berg, dual esc works very good and suddenly it fails : my 'neutral point' where both axles turn at the same speed has been moved to '-50' dual esc mixing point. When I'm at 0 dual esc mixing point the front wheels turn much more than the rear and to find the neutral dual esc mixing rate I have to go to -50. I'm running 2 tekin fxr, I have reseted my radio settings, calibrated my fxr each after each, program the dual esc setting on the radio : always the same trouble (I have to trim on throttle chanel too) Do you see a solution to my issue? thanks |
07-05-2012, 06:57 AM | #1939 | |
07-12-2012, 07:42 PM | #1940 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
Hey Harley, I recently acquired a 4PL. What do you recommend for a rechargeable battery to put in the transmitter? Thanks! Sent from my iPhone using Forum Runner |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
