Thread: xp3d + corona 2.4 ghz
Old 11-28-2010, 03:56 PM   #1
Default xp3d + corona 2.4 ghz
Hi everyone this is my first post here im currently building a venom creeper and this forum help me a lot with good tip on buildindthanks !!!
My question is that i have a Team Associated xp3d radio that i bough really cheap and i want to know if someone as tried the corona ct3f module in their transmitter.
I know that this module work onfutaba 3 pm and some hitec model but on the xp3d?
thanks !
ticric is offline   Reply With Quote
Old 12-13-2012, 09:38 PM   #2
Default Re: xp3d + corona 2.4 ghz
I know this is reviving an old thread, but someone else may want the answer. The Team Associated XP3D is a PPM based system that has a module compatible with 3PJ, 3PJS, 3PM, 3PK, and so on. The Corona CT3F module works perfect in the XP3D radio.
And on anouther note... If the 2.4ghz module says compatible is 3PK then yes its compatible with 3PJ and 3PJS. The manufactures simply choose not to test these older systems.
ShawnCaudill is offline   Reply With Quote
