Thread: Dual ESC et Power Cap
Old 11-29-2010, 07:39 PM   #1
Default Dual ESC et Power Cap
Hello,
Sorry if the question were put several times, but I did not find an answer.
On my Berg, I use dual Tekin Fx-R ESC (since a long moment) with 2 x 40T and 3S LiPo (and Castel BEC). I remade electric wiring, as on the diagram below :
I use one Power Cap for 2 esc, that can create problems to use only one Power Cap ??
Thank you for your answers
TotoRax is offline   Reply With Quote
Old 11-29-2010, 07:42 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You will want as short of wires from one ESC to the other, and the largest wire you can find to decrease the inductance. It would be a good idea to get a lower ESR cap or double the capacitance to reduce voltage ripple as well, but without knowing what ripple you have already I can't give values for it.
In short it is workable, but using two caps would be better for the system.
JohnRobHolmes is offline   Reply With Quote
Old 11-30-2010, 03:14 AM   #3
Big thank you for your clear answer
I use 14awg wire. In fact, I thought replaces the 2 Tekin power cap for one power cap of my Rooster Crawler.
Tekin : 16V 330µF
Novak : 16V 680µF
But I am not a specialist in electronics and I prefer to solicit your advised councils
Old 11-30-2010, 08:37 AM   #4
The ESR of the cap is really more important than the capacity of it. If the novak cap has a higher ESR you are worse off than running two of the tekin caps in parallel.
Old 11-30-2010, 02:44 PM   #5
Thanks
I will take your advice and will assemble 2 x Tekin power cap
