12-22-2010, 07:42 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: sulphur
| winch powering question
well while my husband is in surgury i wanna hook up the winch he got from fred0000 so i need to know if i can run his 3racing winch off the scx10 battery or do i need to use a seperate one, he has a 2s 20c 2100mah 7.4v lipo i can use but im not sure if the winch can handle lipo, thanks in advance for the responces
12-22-2010, 09:41 AM | #2 |
Quarry Creeper Join Date: Jul 2010 Location: netherlands
Howdy. I have the rc4wd winch an run it on a 2s lipo. as far as I understand the 3racing winch should work fine on a 2s lipo.
12-22-2010, 09:45 AM | #3 |
ok i got his winch wired up to the single battery on the truck and it works great, my question now is why wont the truck move, the winch works perfect but the truck bareley moves in forward and if you even slightly touch the trigger it goes full speed in reverse, if i unplug the winch from the reciever the truck works fine in forward and reverse, some help would be appreciated as ide like to have this done when my husband comes back from the hospital
12-22-2010, 03:06 PM | #4 |
anybody, could this be a bec issue, he doesnt have one on the truck yet but i know he has a CC bec on order , would putting a bec in line fix the issue at hand
12-22-2010, 05:19 PM | #5 |
Shouldn't need a BEC if the winch hooks direct to the battery leads.
12-22-2010, 05:54 PM | #6 |
the winch plugs into the esc and is fed power from the battery, the winch works perfect when plugged in but the truck wont do anything, if i unplug the winch from the battery the truck works fine,
12-22-2010, 07:55 PM | #7 |
Any way you can post pics of the setup, I along with many others on this site use that winch. My pos and neg tie in to my deans where the battery hooks to the ESC, then the winch into channel three.
12-22-2010, 10:16 PM | #8 |
ill post pics tomorrow after i get my husband from the hospital and get him settled in at home
