12-22-2010, 10:50 AM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
| Highest voltage
Searched a couple different ways and came up with nothing. I'm wondering what is the max safe voltage I can push through a Sidewinder and stock Axial 55T motor? I have the steering servo and RX run on off a CC BEC set for 6V. I'm running a 7.2 NiMh now, just wondering if I can go bigger, and if so how much? |
12-22-2010, 10:53 AM | #2 |
I've seen folks run 4S lipo with that combo and have no problems. However, Castle recommends no more than 3S (12.6V) max....
12-22-2010, 11:35 AM | #3 |
On thier site they recommend 3s, but cutoff is there for 4s and with a single 55t itll do it no problem. Also voltage is listed as 14 which is almost the full 4s, a pretty good buffer over 3s.
12-22-2010, 01:36 PM | #4 |
| 14v is close to a 4s lipo at nominal voltage but ully charged it will be at 16.8v which is above what castle rates them at but i see no reason it wouldnt be fine since chris from CBP is running 4s on his mamba micro pros which have the same voltage limit and he is running i believe a 35 or 45t motor which draws more current then your 55t
12-22-2010, 02:30 PM | #5 |
My theory is if they wouldn't take it cutoff would have never been added for it, I know mine never get warm on 3s with single motors and my XR sidewinders are gonna see 4s real soon.
