12-22-2010, 02:49 PM | #1 |
| Universal Dyno project with streaming data
I have been after a good motor dyno for some time now. I have used most of the R/C type dynos, and have been disappointed with their overall design. While the typical inertial dyno that we employ works fine for comparing motors within a small scope, it does not give the full picture of efficiency under various loads and the efficiency of high turn motors is generally way out of whack. The scope of this project is a full build from scratch. I will build the drive motor cradle, set up the slave motor system, build a digital readout for gathering figures, and as a final system I will have full datalogging on at least a 5hz resolution. Goals: One dyno for fractional and sub 2100w motors One dyno for higher torque and HP motors universal design with regenerative loads to reduce power supply size torque, power, and efficiency plotted over the entire RPM range of motor (when datalogging system is complete) Cost under $1000, including my labor and raw materials. Easily replicatable So far I have drafted a few designs and have picked up two load cells (simple Wheatstone bridge devices). The first one is a 5 pound sensor that will handle most hobby style motors. The second load cell is a 22 pound sensor that will take the majority of larger motors. The torque arm can be made longer at a resolution loss for motors that are slower speed/ higher torque like an outrunner. I have a few data loggers here already, and have been studying AVR programming in case I need to build a data acquisition device myself. I also have some voltage and current monitors here that will stream tab delineated information via serial connections. Add this into some load cell data and we have ourselves a fully functioning dyno! The next step is to build a stand, calibrate the torque sensor formulas, and get some DROs on it for static point data acquisition. My most important goal with this build is to show exactly what a dyno is, and hopefully offer enough information for a universal dyno to be reproduced by another if they wish. Whether it be hobby motors or full size vehicles, the principles of a dyno are the same. Last edited by JohnRobHolmes; 05-15-2012 at 11:23 AM. |
12-22-2010, 02:49 PM | #2 |
formula and thought spot Force = pressure on an object (newtons and pounds) Work = Force over a distance (newton-meter aka. joule and foot-pound) Power = Work/ Time (horsepower and watts) Torque = Rotational work (newton-meter and foot-pound) Ohm's law- Voltage = Current * Resistance (V=I*R) Electrical Power = Watts = Voltage * Current (W=V*I) Instantaneous Power = Force * Velocity 1 hp = 745.699872 watts 1 watt= 1 newton meter per second 1 foot-pounds = 1.3558 Newton-meters 1 inch-pounds = 0.112984829 Newton-meters 0.1 kg-meter = .980665 nm Horsepower = Torque x rpm / 5252 Torque in ft/lb = (HP/rpm)* 63,025 Torque in N/m = (HP/rpm)* 85,446 --- needs a double check Test modes: Steady state RPM Steady state Torque Steady state Amp Dynamic Last edited by JohnRobHolmes; 09-02-2013 at 08:04 PM. |
12-22-2010, 04:41 PM | #3 |
Subscribed, I love this stuff |
12-22-2010, 05:08 PM | #4 |
Quarry Creeper Join Date: Jan 2010 Location: USA
Sounds like a great project. I can't believe that you are including your labor in the $1000 goal! You must have a very good idea about how this will go together already (and some very clear end goals). Can't wait to see how it comes out.
12-22-2010, 05:15 PM | #5 |
$20 an hour for hiring myself on the cheap, that gives me a full 40 hours of work after materials are considered. It will cut it close for sure, but I see no reason that I can't hit it. This estimation is only for the smaller machine. The slave motor for the larger unit has already blown $1000, but it will take 30hp and is a lifetime investment. If I don't hit the monetary goal, then I may have to build a few more units to subsidize my work time over a few machines The graphical interface will be the tough one. I can buy some ready made software for $600 to $1200, or I can just dump the info into an excel spreadsheet. At any rate, the machine itself is not the biggest hurdle. It is the data gathering and interpretations. |
12-22-2010, 05:36 PM | #6 |
Will be watching this thread!
12-22-2010, 05:41 PM | #7 |
Moderator Join Date: Jul 2007 Location: Texas baby!
12-22-2010, 06:48 PM | #8 |
Here! Sorry I'm late for class |
12-22-2010, 08:28 PM | #9 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Hey John, I actually work for a company that sells instrumentation and sensors. Check out www.disensors.com Data acquisition, torque cells, etc are amoung the products we carry. Not trying to sell you anything, but you can pick my brain if you like. The usual place we start on an app is asking questions like accuracy requirements, measurement rate and of course budget. Seeing as you have already defined the last two parameters, how about the first?? Narly1 |
12-22-2010, 08:41 PM | #10 |
12-22-2010, 09:07 PM | #11 |
John, Re-reading your original post, look at digital read outs (DRO's) that have the capability to provide excitation voltage for the load or torque cells that also include a reasonably fast analog output (to send to a logger). An instrument like I've described + Winwedge software and you'd be off to the races. Narly1 Last edited by Narly1; 12-22-2010 at 09:11 PM. |
12-22-2010, 09:41 PM | #12 |
Sounds like a DRO that can take the 0-10v load cell output and send it to the logger in a 0-5v signal would be the tits! I will certainly pick your brain on the matter, because that solves a few issues for me.
12-22-2010, 09:43 PM | #13 |
I hear you guys talking but what I hear is... |
12-22-2010, 09:48 PM | #14 |
Me stickum motor in machine. Me getum numbers from machine that say good.
12-22-2010, 10:18 PM | #15 |
RCC Addict Join Date: Jul 2006 Location: barstow
thanks for simplifying that for us, i mean oh ok soundum good
12-22-2010, 11:04 PM | #16 | |
Narly1 | |
12-23-2010, 06:39 AM | #17 |
I may be wrong about the output. I need to test them first.
12-23-2010, 08:43 AM | #18 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Subscribed!
12-23-2010, 04:07 PM | #19 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
Hell! I'd buy one. A grand would not be a bad price...ETA?
12-23-2010, 05:56 PM | #20 |
I'm not pushing too hard on it. Once I get the DAQ figured out it will be a few days work to actually build it. Either I have to purchase a signal conditioner, or I will need to make a chip to take the torque sensor output and convert it to 5v analogue.
