12-22-2010, 05:17 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| esc waterproofing
Disclaimer: Im pretty sure this will void any and all warrentee's so only do this if you are positive you need waterproof. step 1: Build a form. I chose to mimic the size of the sidewinder case as I was using a sidewinder. Keep in mind that if you dont use a mold release, your form is a 1 shot deal. step 2: find an appropriate epoxy. I used a 2 part that can be purchased at homedepot. Use a long setting epoxy as the heat up far less and are less likely to damage the electronics. Step 3: Remove the stock case Step 4: Mix the epoxy as per directions, pour some in the bottom of the mold Step 5 insert the esc. Then finish filling until all of the electronics are covered. Step 6: Secure your esc in the epoxy so that it cannot move. It will need to sit like this for 8hrs or more. Step 7: Remove the form from the epoxy. If you used mold release it should easily slide out. If not... Good luck. I chose to not use mold release so that I had a nice flat styrene bottom. |
01-09-2013, 06:51 PM | #2 |
Newbie Join Date: Aug 2012 Location: Brasil
| Re: esc waterproofing
Hello, how about the heating? Any problem with it?
01-09-2013, 07:06 PM | #3 |
Rock Stacker Join Date: Dec 2012 Location: Fremont
cant see the last two pix??? Do you leave the top part of the heatsink out of the epoxy so the heat can leave the esc? |
01-09-2013, 08:31 PM | #4 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: esc waterproofing |
01-10-2013, 05:00 AM | #5 |
Ill try to fix the last couple pics... you leave the heat sink out, just enough epoxy to cover the board. Ive ran them like this for a couple years without any issue.
01-10-2013, 05:12 PM | #6 |
Thank you for the feedback! I will try this metod and if i have any problems i will post here. Bye! |
