12-22-2010, 11:34 PM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: West Melbourne, Florida
| Which esc/motor
I have the stock motor and VXL-3 ESC in my scx10 rtr, and would like to upgrade because the motor isnt very strong, and the ESC doesnt have a very good drag brake. I hear alot of good things about the CC Mamba Max Pro, and the Novak Rooster Crawler systems. My truck isnt a comper, I run it in the water occasionally, so I need an ESC that is somewhat good in water. I had a CC Mamba Moster system in my Slash 4x4 and it killed any competition, what is a good, strong motor that would work well with the CC Mamba Max/MM Pro. And what is the difference between a Mamba Max "pro" and just the Mamba Max? |
12-23-2010, 12:25 PM | #2 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
just get a new motor.. VXL is the only ESC that is submerge-able.
12-24-2010, 03:15 PM | #3 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
MMP can use sensor and senserless, can hand more volts, has a fan, more adjustabilty and I think it is cheaper because its newer | |
12-24-2010, 03:58 PM | #4 |
Quarry Creeper Join Date: Oct 2010 Location: sulphur
if you plan on ever runnin in any water i would suggest the xl-5 and a cheaper 35t motor like this one http://store.rc4wd.com/540-Crawler-B...35T_p_821.html , i personally have 3 of these motors and im still on the first one and it has seen this kinda mud its whole life goin on 5 months now |
12-27-2010, 02:32 PM | #5 | |
Pebble Pounder Join Date: Nov 2010 Location: Texas
12-27-2010, 04:29 PM | #6 |
In pretty sure the trinity motors have issues. My Titan 550 motor was ran in deep mud no problem.. It could just be the brushes you use..
12-27-2010, 04:48 PM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Remove the onboard trinity caps and you should not have any glitching issues.....they certainly do not like to get wet. Unless you are glitching in the first place, they are not really needed with newer radios, recievers and escs....at worst, you can solder on some normal motor caps if you need them and they are plenty water proof. Later EddieO |
12-27-2010, 04:58 PM | #8 |
Quarry Creeper Join Date: Aug 2008 Location: San Jose
If you are just bashing most of the time and want to run into water and mud with no worries and no modding, then I would suggest the XL-5 esc and a cheaper motor. You can also get Holmes' BR-XL waterproofed version (if he starts selling the waterproof version again). If you want to do a little modding (ie creating a waterproof box), I think an FXR is great, expecially since it has such a small footprint. As far as brushed motors go, they are all 'waterproof' but if you continually run in water/mud, they will require much more maintenance and will not last as long. |
12-27-2010, 10:10 PM | #9 | |
