12-26-2010, 03:42 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
| Wireing help
I have a mamba max pro esc and a ccbec 10amp. Anyone have a dia on how to wire up a 7.4 steering servo with the ccbec and use the mmp bec at 6v for a dig servo. Thanks
12-26-2010, 04:39 PM | #2 |
RCC Addict Join Date: Nov 2010 Location: England
have a read of this thread. it is very helpful. post#19 has a diagram that shows how Definitive wiring diagrams for BECs Rx Servos Motors etc. use the mmp ESC to power the receiver and the dig servo. use the ccbec to power the steering servo, but you must disconnect the signal wire from the ccbec. run the signal wire form the steering servo to the receiver. you can remove the signal wire from the 3 pin plug by lifting the tab with a small screwdriver or knife |
12-26-2010, 05:54 PM | #3 |
Thank you I will read and and try and hook it up this way.
