12-27-2010, 03:10 PM | #1 | |
Newbie Join Date: Dec 2010 Location: Austin
| 35T motor?
Want to run a 35T motor in my Axial Honcho Crawler but cant find a holmes anywhere, wrote their website and this is what i got back, Quote:
12-27-2010, 03:12 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
Do you want a machined or hand wound motor?
12-27-2010, 03:21 PM | #3 |
| ... Integy 35 turn. Advance the timing to somewhere between 4 and 8 degrees and have at it. They can be found practically everywhere. |
12-27-2010, 03:23 PM | #4 |
Im open to arguements for either.
12-27-2010, 03:26 PM | #5 |
12-27-2010, 03:31 PM | #6 |
| What I was looking at... was in the $25 dollar range http://holmeshobbies.com/product.php...7&cat=0&page=1 |
12-27-2010, 03:35 PM | #7 |
An integy is about the only thing you will find in that price range.
12-27-2010, 03:37 PM | #8 |
12-27-2010, 03:42 PM | #9 |
A 1300 3s is what I typically run. You can get away with a 25c pack, but a 35c will have better punch and last more cycles. Many people work with smaller packs like 850s, but I don't recommend them unless you get free packs or plan to replace them every 30 runs or so. Going to a handwound puts more stress on the pack too, and that is all I run. With a machine wound you won't need quite so much pack power. |
12-27-2010, 04:01 PM | #10 | |
12-27-2010, 04:05 PM | #11 | |
I was running 55t machine wounds on 500mAh 3s lipo's,never had an issue Then I droped in a set of 35t handwounds,I still didnt have any issues though I did notice my cells was taking longer to balance. I'm using thise same batteries and I have used them for 13 reg comps,1 state finals,4 large comps and nationals and numerous fun runs. Now I have noticed a drop lately in thier performance,and I have killed 2 packes recently,I also only run one pack per course and plan on going up to 850's So I would say John is probably about dead on with the need to replace after about 30 cycles if ya go with a smaller mAh. | |
12-27-2010, 04:11 PM | #12 |
A good indicator is the pack temperature as well. If they warm up (or swell) during a run, the internal resistance isn't low enough to handle the load easily. While you can always go smaller than my recommendations, I typically will recommend a setup that gives a long reliable life for maximum $$ value. If you want maximum performance then things can be tweaked a bit, and component life will be shorter. Some people are totally OK with replacing a pack every 30 runs or replacing a motor every few hours of runtime.
