12-28-2010, 02:54 PM | #1 |
Newbie Join Date: Dec 2009 Location: Seattle
| LIPO setup question
So here is the question, I'm setting up my Hustler SE with a pair of super bullies. I will be running a Mamba Max Pro and Tekin 21.5 Brushless front and rear and am getting ready to order my lipos. Then I got to wondering if I need two sets of lipos (one for each speed controller/motor) or if I can run both speed controllers/motors from one lipo and if so what should I use? I was originally thinking of running two sets of lipos each a 3s separately to each speed controller but if I use just one set should I or could I go with a 5s and run a Y connector to power each speed controller. I hope someone can understand what I'm trying to say here and appreciate your advice. Thanks. |
12-28-2010, 05:55 PM | #2 |
you can either run one lipo per esc or use only one lipo and run a y connector to both for either the 3s or the 5s
12-28-2010, 08:03 PM | #3 | |
How are most people powering a dual esc/motor setup? | |
12-28-2010, 09:28 PM | #4 |
Just use one pack, and run a Y harness to the ESCs. Running one battery per ESC can cause current flows through the RX and screw up the ground reference.
12-28-2010, 10:04 PM | #5 |
12-29-2010, 04:19 AM | #6 |
No sweat!
