12-29-2010, 11:33 AM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: St. Lawrence County NY
| Steering Servo Glitching w/ Throttle
I tried searching and really couldn't find anything helpful. With my servo plugged into the CC BEC I'm getting a lot of glitching when I apply any throttle. With the servo plugged directly into the receiver it does not glitch at all. Any suggestions?
12-29-2010, 11:46 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
feed your receiver with the BEC and remove the red wire from your esc going to the receiver. this will solve it. my MRC done the same thing. my 2.2 sportsman rig doesnt have that problem (yet) so now I have my castle BEC wired in two different ways on two different setups. works fine. best thing, you dont need to mod your servo wiring, since the bec feeds the rec and servo both. your lipo will feed your esc by itself. should clean it right up! |
12-29-2010, 11:56 AM | #3 | |
Will it still be safe to use the 7.4v BEC setting with this setup and not harm the Rx? I'm assuming (I know, ASS out of U and ME ) I plug the BEC into the battery channel on the Rx? Last edited by Airmaxx23; 12-29-2010 at 12:02 PM. | |
12-29-2010, 12:25 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Oregon
This is the best way to wire your BEC. |
12-29-2010, 12:33 PM | #5 |
thats how my original wiring went on my sportsman. BEC amped up the servo only. if you get glitches, like tight quarters on an MRC and little to no room for spacing out your electronics, i had to feed the rec and servo 6v from the bec. if he feeds over 6v to the rec, it might either not like it releasing the magic smoke, or choke it down to the voltage it wants possibly. im not sure about input voltages on recs tho, how much they can handle... |
12-29-2010, 12:39 PM | #6 |
12-29-2010, 12:42 PM | #7 |
yes sir you should be golden! i need to see what my Futaba 3ch can take in. |
12-30-2010, 11:46 PM | #8 |
Quarry Creeper Join Date: Feb 2009 Location: IN MY HOUSE
YEARS AGO I figured out that the arms/knuckles bouncing around were causing glitches...I put small oring on each side of the knuckles and the glitching went away.....stray ground power.. |
