12-30-2010, 07:38 PM | #1 |
Quarry Creeper Join Date: Jun 2009 Location: ...
| Not enough drag
Ok, so I got an fxr pro and a 35t integy and the drag brake is all the way up on the fxr. my crawler still wants to coast a bit. it's just not holding. any suggestions? what's the problem?
12-30-2010, 07:40 PM | #2 |
12-30-2010, 07:43 PM | #3 |
Does it coast just a touch,or will it not hold at all. what battery,2s,3s,stick pack? You can get some extra heavy springs for the brushes,that should help. |
12-30-2010, 07:48 PM | #4 |
Check the neutral settings on your radio as well. If it is set slightly forward or backward, it will tend to coast a bit. And yeah, like EP said, a new, quality motor will do wonders for drag! |
12-30-2010, 07:54 PM | #5 |
The motor is fairly new but the truck isn't that heavy it's 5lbs 2oz with the battery and I'll say it would probably creep down a decent grade
12-30-2010, 07:56 PM | #6 |
12-30-2010, 07:57 PM | #7 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
if your trim isn't the issue i'd try another motor, I had a fresh out of the package venom 55t and it would not hold at all with the drag brake, put in the old integy motor and it'll do stoppies.
12-30-2010, 08:03 PM | #8 |
Alright I'll check the radio settings out but I've been lookin for an excuse to try a br00d motor so I'll try that to Thanks guys |
12-30-2010, 08:04 PM | #9 |
12-30-2010, 08:10 PM | #10 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| ok
I have an fxr and a 35 t hh and my break is set on 5 i thick and if i am on the throt and let off it will almost flipp over .i thinck you you need a better motor
12-30-2010, 08:34 PM | #11 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
I'm not a fan of Integy products, however I do have a V11 35T running on 3s and an FX-R in my 9 pound scaler, and have no issue with drag. I did add Trinity Purple springs but other than that it's stock. Unfortunately I think they're hit or miss. I run a Br00d 40T Creep Type R in my 2.2 (5lbs 9oz) on 3s and an FX-R and it will roll slightly even at 100% drag. For what I was looking for in a motor I gave up a bit of mechanical drag in favor of smoother low end/start up. Honestly, I modified my drive style for the better because of this motor. As Jeremy said, you will not be dissapointed with a Br00d |
