01-03-2011, 08:18 AM | #1 |
Pebble Pounder Join Date: Apr 2008 Location: Marion
| Wrong voltage
When I hook one of my battery packs,, a duratrax shark 7.2 1500 nicd, to my charger it starts but then alarms Wrong Voltage, it has junk tamiya connector on it, it is just for set up, What is wrong,
01-03-2011, 08:26 AM | #2 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
What kind of battery and charger are you using? Here is a couple of things it could be, 1. Your charger could be set to charge a higher or lower voltage pack then you are trying to charge, 0r 2. It could be that the packs voltage is to low and is out of range for your charger to charge the pack. |
01-03-2011, 08:35 AM | #3 |
I am using a ONYX 230 charger , The battery is a Duratrax shark nicd 1500, I have 2 of them and the other one chrges normal.
01-03-2011, 08:41 AM | #4 |
| Could be a bad battery, you might try checking the voltage of the battery in question with a volt meter to see if it is in 6-8volt range, if it got over discharged it can damage the pack and will not take a charge.
01-03-2011, 03:02 PM | #5 |
I just checked it and it reads 7.8 v so it isnt a discharged battery
01-03-2011, 06:11 PM | #6 |
So Now ,any ideas ?
01-03-2011, 08:04 PM | #7 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Could be that Tamiya connector, they fail at the drop of a hat. Could also be a bad cell, or battery bar connection. If you can get it to charge or discharge, use a temp gun to check for hot spots. If you find an area or cell in the pack that is hotter than the rest, you found your problem.
01-03-2011, 10:34 PM | #8 |
The 230 is a decent charger, make sure you have it set for the type of battery that you are charging. Look at the manual that came with it, it gives you guide lines for setting the correct voltage and current values for NiCd and NiMh batteries.
01-04-2011, 07:31 AM | #9 | |
OP, as mentioned before, it's possible you have one cell that is failing which is causing issues when charging. It could also be those frikkin connectors. Look inside the "barrel" of the connector, see if it's shiney looking or dark (like it got hot). Sometime you can pop the barrel out and slightly squeeze it smaller to get a better connection. Long term, use a different connector (Deans, Sermos, etc.) | |
