01-03-2011, 08:53 AM | #1 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
| Castle BEC question PLEASE HELP!
Hey guys, so this morning, i came across an interesting post, which was originally posted in 09. so my question is, can you really leave the red wire from the ESC connected to the RX to help with the load? are there any downsides? thanks |
01-03-2011, 09:08 AM | #2 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
No. It does not "share" the load... the BEC powers only the servo it's hooked up to, and the esc's built in BEC (if you still have it hooked up) would only power what is hooked up to the rx like additional servos. If you run the CC BEC through the esc and still have the red esc wire hooked up, you risk problems by back feeding. The external BEC is to avoid hi voltage spikes cause by power hungry servos we are using these days. I wouldn't have started a whole new thread for this question that could have been asked in the thread you got the idea from. Last edited by rockhugger; 01-03-2011 at 09:11 AM. |
01-03-2011, 09:12 AM | #3 | |
well, i was going to, but the thread was originally posted way back in 09.. | |
01-03-2011, 09:31 AM | #4 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
| a good reason for keeping it in that thread would be so that we could see the post you were speaking of, and perhaps make sense of it to you.
01-03-2011, 09:32 AM | #5 |
what it means is the + and - wires on the bec hook right up to the servos + and - wires and only the seros signal wire goes to the rx that way the servo gets all the power it needs or the voltage can be set higher for the newer high-voltage servos
01-03-2011, 09:34 AM | #6 |
| so essentially you taking out the +/- from the servos RX connector, and using the CC Becs +/-?
01-03-2011, 09:35 AM | #7 |
01-03-2011, 09:38 AM | #8 |
btw is there a drawback of hooking up the servo directly from the bec?
01-03-2011, 09:40 AM | #9 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
i did this and now my servo glitches and turns left when i hit the throttle only the signal wire is connected to the rx so im really confused it doesnt do it when the cc bec is taken out of the loop |
01-03-2011, 09:41 AM | #10 |
| is your ESC Red wire still connected?? that could be it. since both BECs casue issues.
