01-07-2011, 03:55 PM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
| Mamba Max Pro help.
I just got my Mamba Max Pro and after programing it to what I want I took it out for a test drive and this happens, when I'm easing into the throttle just before I pull half way it all of a sudden releases this burst and it goes balls to the walls, this is a problem for rock crawling because when I'm on a rock and I need a bit more if I hit that point it releases this burst and my rig goes flying over the rocks at this high speed, I don't know what to look for in the programing section to make it an easy transition from 0% throttle to easing all the way too 100% if need be, with out it jumping to a higher speed at the half way point in my pull of the throttle. Oh I'm running a Velineon 3500 Kv brushless motor, if anyone else has a mamba Max Pro if you don't mind can you tell me what settings you guys have? Thanks. I hope this makes sense. Here's a video. At 6 seconds it does it. http://www.youtube.com/watch?v=VknwYKdNv1c Last edited by arctichorse; 01-07-2011 at 04:06 PM. |
01-07-2011, 05:36 PM | #2 |
Have you programmed your radio to the ESC? Sounds like that needs to be done.
01-07-2011, 05:38 PM | #3 | |
Rock Stacker Join Date: Mar 2009 Location: lake odessa
01-07-2011, 06:17 PM | #4 | |
Set on 0% and it still does it. Last edited by arctichorse; 01-07-2011 at 07:29 PM. | |
01-07-2011, 08:21 PM | #5 |
If you connect a servo to the throttle channel, is it jumpy too?
01-07-2011, 08:25 PM | #6 |
Newbie Join Date: Apr 2010 Location: Oxford, AL
mine was doing the same thing when I first got it as well, it ended up being my transmitter wasn't set right... |
01-07-2011, 08:35 PM | #7 |
| Nope, it doesn't act jumpy.
01-07-2011, 08:39 PM | #8 |
Quarry Creeper Join Date: Aug 2008 Location: Northern, Mi
What TX are you using?
01-07-2011, 08:39 PM | #9 |
Rock Crawler Join Date: Jun 2009 Location: summertown
1: check your throttle curve (make sure it ramps up from the bottom left corner to the top right corner in a STRAIGHT line) , disable punch control 0%, set start power on high, these are just a few to check |
01-07-2011, 08:51 PM | #10 | |
What did you have set wrong, maybe mine is the same problem, thanks. Last edited by arctichorse; 01-07-2011 at 08:59 PM. | |
01-07-2011, 09:00 PM | #11 |
I have the futaba 3pmx and I cant remember exactly what the setting was but it had to do with the throttle curve on the transmitter side, once a friend dialed it down for me, I had never used this transmitter at this point, it was buttery smooth. I wish I had it here to tell you more, but I'm in VA and it's in MS right now.
01-07-2011, 09:45 PM | #12 |
Shoot, oh well, seems like my ESC just doesn't like low speed.
01-07-2011, 11:42 PM | #13 |
Do you guys think it could be the BEC going bad? I have variable speeds for each time I pull the throttle. Or could it be the radio? I'm using a Traxxas TQ 2.4gh radio.
01-08-2011, 05:41 AM | #14 |
01-08-2011, 08:17 AM | #15 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
| X2....I know there are people out there running the velineon setups in crawlers, but the one time I stuck a brushless castle motor in my rig it did a similar thing. It would cog badly If I tried to jump into the throttle to quickly, so I would ease in and them BAM off she went....off the table off the rocks off the well you get the point. If you go full throttle from a dead stop, does it sit there a sort of twitch ?
01-08-2011, 10:10 AM | #16 | |
01-08-2011, 10:16 AM | #17 |
| I was wondering that myself but even sensorless shouldn't have this problem, it could be the firmware because when I down loaded the 1.26 version this morning and my problem went away.
01-08-2011, 12:26 PM | #18 |
Problem fixed, it was the 1.30 firmware update for me, I down graded the firmware to the 1.26 update and it works perfectly now.
