01-07-2011, 05:27 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Jasper
| 35t Yokomo Drift Motor work in my scx10
Hey , Well i decided to get a TR SCX10 Dingo to play with . I have a FX-R esc on the way , put in a Hitec HS-645mg and I don't care for the 27t stock motor . I have a couple new Yokomo 35T drift motors laying around and wondered if they would work till funds are available for a better motor .
01-07-2011, 05:33 PM | #2 |
As long as you are running it in the right direction. You can't adjust the timing on them, so counterclockwise is all you can safely run for forwards.
01-07-2011, 06:36 PM | #3 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
They should work, I would check the timing though, as a lot of them were based on 23t stock motors, so they have 24 degrees of timing.....if they are locked timing, you can just cut the little tab off the endbell and then it will rotate. Later EddieO |
