Thread: What are your MOA FXR settings.
Old 01-08-2011, 11:35 AM   #1
Default What are your MOA FXR settings.
Just curious what everyone else is running for them. I have both FXRs set to these settings.
led 1: Drag brake, = 10
led 2: Reverse strength, = 11
led 3: Current limiter, = 1
led 4: Push control, = 1
led 5: Reverse type, = 2 (instant rvrs)
led 6: Voltage cut off, = 3 (3s lipo)
Krakker is offline   Reply With Quote
Old 01-09-2011, 06:47 AM   #2
I have mine set very similar to yours:
led 1: Drag brake, = 7
led 5: Reverse type, = 2 (instant reverse)
led 6: Voltage cut off, = 2-3 (depending on which pack I'm using)
Airmaxx23 is offline   Reply With Quote
Old 01-09-2011, 01:24 PM   #3
Mine is similar also but I use a hotwire so I dont know how that compares to the pit tuning. The only difference in those settings that I have is that my front esc has less drag brake than the rear. I think its like 5 on the front and 10 on the rear. It helps out on steep downhills to have the front roll out a little bit so you dont go over the front...I havent noticed it rolling backwards on uphills either.
SMR 510RR is offline   Reply With Quote
