01-10-2011, 08:45 PM | #1 |
Pebble Pounder Join Date: Jul 2009 Location: orinda
| Punk dig problem
So I searched and couldn't find anything so here it goes! I set up my punk dig wi an fxr and my dx3r. I haven't changed any of the adjustments on the radio except making the "E" switch my aux switch. My problem is when I use the the rear dig it works fine, and when I'm in 4wd it works fine. Now when I go to do front dig , I get 4wd again, any ideas? Thanks again!!
01-10-2011, 08:54 PM | #2 |
You have it set as "AUX 3P" correct??
01-10-2011, 08:57 PM | #3 |
01-10-2011, 09:01 PM | #4 |
Travel for that channel set to 100% for both high and low?? Trim set to zero for that channel?
01-10-2011, 09:04 PM | #5 |
You bet! Still same problem
01-10-2011, 09:06 PM | #6 |
If you switch Motor 1 and Motor 2 leads, does the problem follow the motor?
01-10-2011, 09:43 PM | #7 |
Do you hear a nice click when you switch to the side that isnt working? Does the LED change colors?
01-10-2011, 10:09 PM | #8 |
01-10-2011, 10:22 PM | #9 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
Sounds like the relay for the front motor isnt working and is staying on!!! Email punk and they should send you a replacment
01-10-2011, 10:31 PM | #10 |
| Done kinda sucks that it didn't work straight out of the box but that's more than fine I know complications happen I'm not upset with it at all
01-10-2011, 10:44 PM | #11 |
Pebble Pounder Join Date: Oct 2010 Location: florida
Right out of the box mine never got power to thr front motor, posative pole had 0 voltage. I sent it off about a week ago.
01-10-2011, 11:20 PM | #12 |
Hopefully I get a quick response from them on that!
01-10-2011, 11:43 PM | #13 |
01-11-2011, 06:31 AM | #14 |
01-11-2011, 09:16 AM | #15 |
Ya hopefully I get a response today on it! If it is just a defect hopefully I can send it in or get sent a new one!
01-11-2011, 11:12 AM | #16 |
Newbie Join Date: Oct 2010 Location: Omaha
It's also possible that one of the diodes is bad. I got a used Punk with busted diodes a while back and the light would change, but there was no Click and the motors stayed on regardless of the position. I soldered on some new diodes and it seemed to fix the problem. However, if I had gotten the Punk new, then I would have sent it to him for the repair. |
01-11-2011, 11:12 AM | #17 | |
Quarry Creeper Join Date: Apr 2009 Location: KC
I never got a response from him on mine when I sent it back for repair (my fault) it showed up in the mail a little over a week later fixed... NO CHARGE! Robin really stands behind his product! | |
01-11-2011, 11:55 AM | #18 |
| Good to hear! Did you contact him first and talk to him or did you just send it right in?
01-11-2011, 12:02 PM | #19 |
Quarry Creeper Join Date: May 2009 Location: brentwood
You may try calling Mike Mann at Hobbytown Concord, 925-685-3802. He may be able to point you in the right direction and get you results |
01-11-2011, 12:15 PM | #20 |
| Funny you should say that seeing as I work there! I was just looking to see if anyone had input until next time I'm working (Thursday) so I could get the truck running for the course!
